Author Topic: Replacing 16" alloy with 17"  (Read 3319 times)
dpanic88
  • West Midlands
« on: 22 December 2008, 19:55:07 »
 :-? - just a general question, might be easy answer. Have 16" alloy on 2001 2.2dth estate - two have bent rims, looking at 17" Elite wheels to replace. Do you have to do any thing suspension wise or can you just swap them over - just different tyres.
many xmas regards -
dpanic88
Re: Replacing 16" alloy with 17"
« Reply #1 on: 22 December 2008, 20:05:03 »
......, looking at 17" Elite wheels to replace. Do you have to do any thing suspension wise or can you just swap them over - just different tyres. .......
Not worth the hassle  ..... loads of things to change over. ;)
I'll buy your 17" Elites off though you to save you the hassle of getting rid of 'em!  ;)   ;) :y  :y  :y
No! Just bolt them on! I don't see any reason for changing the size of the rubber already fitted to the 17"'s :y
dpanic88
  • West Midlands
« Reply #2 on: 22 December 2008, 20:08:33 »
ok thanks
not purchased the 17" yet.. just looking as tyres on three of mine are almost out as well as the bent rims. so I thought why not and go for it.
ta
Albatross
  • Bedford
  • An LSD & an S2000!
« Reply #3 on: 23 December 2008, 03:07:06 »
Bolt straight on and solve all your problems. I've seen full sets with 4 good tyres on them for less than the price of 4 new tyres.
Go for it; you know you want to. Replacement tyres won't be much more, if anything, either when it comes round.
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #4 on: 23 December 2008, 14:59:44 »
avons are about 74 pounds a piece on camskill ;)
thats the zz3's or about 80 for the zv5's
and those are 235/45/17
V8!!!!
Ironingboard
  • Edinburgh
« Reply #5 on: 23 December 2008, 15:56:08 »
Will the speedo not be affected having a larger tyre. Think I read that somewhere since the tyre is larger and hence takes a longer time to do a full rotation compared with a 16" one. Ok its only an inch but it makes the difference speedo wise.
Welung666
« Reply #6 on: 23 December 2008, 16:13:04 »
many xmas regards -
dpanic88
Nice to see another poster local to me too :y
waspy
« Reply #7 on: 23 December 2008, 16:15:05 »
You're changing from 16" to a 17" wheel & lets say you didn't change the profile of the rubber. The extra inch diameter would put your speedo out by minus 7%. So at 100 mph you would be doing 107 mph. So at a lower speed say 10 mph it's only 0.7 mph more & so on :y
« Reply #8 on: 23 December 2008, 18:52:50 »
If you look here on page 226 you'll see that as the trye rim diameter then the profile comes down ie a 15" has a 65% profile & a 17" has a 45% profile so that the rolling radius of both sizes of tyre and rim is near enough the same, so your speedo is still happy.  :y
dpanic88
  • West Midlands
« Reply #9 on: 24 December 2008, 08:38:06 »
hi many thanks for the info, purchased 4 - should be here next week.
just now need to get rid of two of the 5 alloys - two duff , bent and leaking air, one will keep for spare, two leff i'll post a any note in the for sale - 2 x 16" Free to a good home :D :D
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #10 on: 24 December 2008, 11:21:34 »
17s will rub the arches if the wishbones are nackered!
dpanic88
  • West Midlands
« Reply #11 on: 27 December 2008, 15:50:23 »
will do - have replaced the front two recently (only done about 7k on these current ones).
But thanks for the heads up - will keep fingers crossed :)
« Reply #12 on: 27 December 2008, 17:45:17 »
There is a setting for wheel sizes on instrument panel and MID/GID/CID, with 195/65/15,235/45/17 on one setting, and 225/55/16 on another.
« Reply #13 on: 27 December 2008, 23:22:50 »
But ...... how will your car know? If the running diameter is the same-ish, and the speedo is the same-ish, then surely what the MID thinks is on the car is irrelevent?????  :-/   :-/  :-/  :y
ngrainqey
  • rotherham
« Reply #14 on: 27 December 2008, 23:58:30 »
the percentage ratio is a percentage ratio of the total width of the tyre though... i had an interesting time working out what tyre ratios the tyres should be on different size wheels and different width tyres...fun being the operative word :P
V8!!!!
Page created in 0.036 seconds with 16 queries.
