Author Topic: Smoking like a trooper  (Read 1344 times)
bago
  • Leicester
    • face lift 2.5 Elite bus
« on: 07 January 2009, 10:41:57 »
Hi recently bought a 99 V reg 2l cd saloon engine started to run a bit ruff after a couple of weeks replaced air mass sensor and also coil leads. Christmas day of all days it started to put out a battleship sized smoke screen- Out the exhaust, checked took the oil filler cap off smoke comimg out of there as well, and when i removed the dipstick out of that as well. Suggestions helpful repair possible or new engine.
ps if new engine where best to try for a reliable one
« Last Edit: 07 January 2009, 10:43:27 by bago »
Re: Smoking like a trooper
« Reply #1 on: 07 January 2009, 12:55:38 »
Could the smoke be steam? are you loosing coolant? Is there water in the oil? Hope its not the head gaskit. If so, repair, not to bad a job on the 4pot if the manihold studs come out ok.
« Last Edit: 07 January 2009, 12:57:45 by chrisgixer »
n538 yky
« Reply #2 on: 07 January 2009, 13:04:58 »
what color is the smoke if it is blue its burning oil and if its white then it is something to do wid water
bago
  • Leicester
« Reply #3 on: 07 January 2009, 14:54:29 »
smoke is bluish Ps engine still runs Been sugested that it could be pistons gone
« Reply #4 on: 07 January 2009, 16:30:38 »
Or valve stem seals, how many miles? Has it ever run low on oil, maybe if the low oil check light has failed ?
bago
  • Leicester
« Reply #5 on: 07 January 2009, 16:50:05 »
its done 11900 ,miles and has not ran low on oil  checked reguarly
