Author Topic: sunroof with mind of its own  (Read 3587 times)
omegav6est
  • corsham wiltshire
« on: 06 January 2009, 23:30:35 »
hi all since we have had this cold snap(-9 here)my sunroof has started to behave strangly.i will be driving along when it will start to open all on its own,it only goes up to the first one or two clicks and its more annoying than anything just wondered if anyone else had experianced this.?thanks
Re: sunroof with mind of its own
« Reply #1 on: 06 January 2009, 23:47:58 »
Mine's been doing it for a couple of months now... No faults logged when the tech 2 was plugged in... Strange thing is that it seems to do it loads of times on oof journey and then be fine for ages!
« Reply #2 on: 06 January 2009, 23:50:01 »
Try a reset as the easiest cheapest fix first. Push in and hold at fully open, closed & tilt, and wait for movement to stop at each position.
sneakypenguin
  • Birmingham
  • Xbox gamertag MagicGinjaninja
    • 07 Volvo V70 T5
« Reply #3 on: 07 January 2009, 00:01:20 »
or call a priest? an exorcism may help wonders  ;D
07 Volvo V70 T5 SE ex police
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #4 on: 07 January 2009, 00:30:39 »
As Andy B says, do a full reset (have you had to jump start recenty?), full open, tilt, close, and hold the switch in for a least 5 sec on each one.
May want to do all the windows as yer there.
« Last Edit: 07 January 2009, 00:31:02 by zirk »
« Reply #5 on: 07 January 2009, 00:35:23 »
had this on mine, but after dis connecting the battery, went to reset, after reconnection and it would not close the last 2 inches. had to disconnect the battery again to unset it/make it need re setting again. Then, after a couple of attempts, and a panic as it was raining by then, i reset in the open position first, THEN the closed and tilt position and all was well. Don't ask me why, no idea... :-/
« Reply #6 on: 07 January 2009, 00:37:16 »
ah, a specific order, might be why?
« Reply #7 on: 07 January 2009, 07:57:16 »
Ljay's opened on its own yesterday, most bizarre!
Weds
  • Chatham, Kent
  • My other hobby
    • Mercedes E class 350 CDi
« Reply #8 on: 07 January 2009, 08:33:37 »
Mine did that yesterday too, noticed the increase in road noise, checked all the windows then noticed the roof had just tilted slightly.
How strange its happened to so many of us..
hoj
  • BURY
« Reply #9 on: 07 January 2009, 09:07:22 »
How wierd mine opened too the other day (and i blamed the Mrs. lol)
Mind you my radio has a mind of its own as does the trafficmaster and the alarm never figured out why yet
3.2 Elite in Oyster
« Reply #10 on: 07 January 2009, 09:20:09 »
Completely off topic .............  ::)
What colour is your Lotus Cortina? Just asking as I saw a slate grey-ish MkI the other day ( can't remember exactly where now :-[ ..... looked to be a bit souped up too.  ;)   ;) ;) ;) :y
Omegadoha, Desert Member
  • Doha, Qatar
« Reply #11 on: 07 January 2009, 11:40:34 »
This appears to be quite common! Mine does exactly the same. Driving along and it will open by itself. I call it an auto sunroof feature.  :)
garbage456
  • Carshalton, Surrey
« Reply #12 on: 07 January 2009, 12:48:02 »
i hear mine buzz open a notch or 2 then it goes and shuts it self, very scary at 1am in the morning
SteveMJ
  • Hertfordshire
« Reply #13 on: 07 January 2009, 12:48:54 »
Mine loses the end/mid point setting every now and then.
One touch is great until you leave the sunroof open overnight (in summer in the garage) and it won't close - just re-opens until manually held as per a reset.
I've never been aware of any fix for this.
Steve
Steve
Richgm
  • Tamworth
« Reply #14 on: 08 January 2009, 13:27:29 »
Mine does it too. To be honest it's that intermittent (once or twice a month) that I didn't think it was worth the while trying to fault fine the problem.
Noli nothis permittere te terere
