Pages: [1] 2 3  All   Go Down
Author Topic: 2.5 TD Glowplugs.  (Read 4669 times)
osealy
  • dublin
2.5 TD Glowplugs.
« on: 06 January 2009, 12:14:15 »
Woudn't start the other day. I pulled the connector. I have 3 failed plugs.
Anyone know which pin matches which cylinder.
Some are easier to change than others.
Last time I couldn't get the manifold off the studs.
Thanks
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
Re: 2.5 TD Glowplugs.
« Reply #1 on: 06 January 2009, 12:34:55 »
do you mean which pin from the wiring goes to each glowplug??
afaik they all just wire up the same - there is no specific order with the wiring
« Last Edit: 06 January 2009, 12:35:46 by PaulW »
Humbugs...
platty
  • Cambridge
    • BMW 530d Sport
« Reply #2 on: 06 January 2009, 12:59:01 »
I changed mine with the inlet still in place - had a few bad ones but changed them all for peace of mind.
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #3 on: 06 January 2009, 13:47:51 »
Change all of them & avoid the cheap ones on e-bay
Beru are the OEM manufacturer circa £11 ea
Wired in parallel so any lead to any plug
osealy
  • dublin
« Reply #4 on: 06 January 2009, 14:48:53 »
Yes! there are six pins on the connector 3 are dead. Are you sure about the parrallel bit?
And I had already ordered some ebay ones . Wellman 20£
« Reply #5 on: 06 January 2009, 18:16:59 »
They are individually wired from glow plug to glow plug relay, where they are all joined in parallel, if that makes sense.
I have 5 out of 6 faulty glow plugs, but can't face changing them in this weather ::)
osealy
  • dublin
« Reply #6 on: 06 January 2009, 18:34:41 »
I'm surprised you can start at all with 5 down. I had to crank for ages this pm 2Deg.
Do you know which pin is which plug. I'm hoping the dead ones are the easier. I also don't fancy changing 6 in this weather.
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #7 on: 06 January 2009, 18:38:42 »
get them all changed, you know you want to :P
saves time in the long run anyway as you'll have changed them all so none should go any time soon ;)
V8!!!!
Pitchfork
« Reply #8 on: 06 January 2009, 18:52:01 »
Once one goes the rest soon follow in sympathy!
osealy
  • dublin
« Reply #9 on: 06 January 2009, 19:10:18 »
The pin order is 123789 so now I need to find which are dead. I think 3 is the easiest to get at.
berserkerboy
  • Llansadwrn, Carmarthenshire SA19
    • 3.2 V6 Elite 02 LPG
« Reply #10 on: 06 January 2009, 20:13:28 »
It's obviously that time of year. -3 deg when I left work this evening and the tractor just wouldn't start. I'm sure it's the glowplugs.
Anyone done this job? They appear to be very difficult to get at with a manifold above them. Do I need to remove this?
osealy
  • dublin
« Reply #11 on: 06 January 2009, 22:13:18 »
It's very awkward especially if they break. & see plattys post.
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« Reply #12 on: 06 January 2009, 22:21:17 »
£7.05 plus VAT from GSF - and they normally supply Beru..BTW that's for an E34 BMW 525tds
« Last Edit: 06 January 2009, 22:22:05 by philhoward »
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #13 on: 07 January 2009, 00:34:02 »
Ive got only 2 working out of 6, still fires up first time !!
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #14 on: 07 January 2009, 12:39:26 »
Yep - inlet manifold needs to come off .... !
Once it's removed, stuff some rags in the inlet ports on the cylinder head to prevent any foreign bodies entering the combustion chambers while your changing the plugs.
Pages: [1] 2 3  All   Go Up
