Pages: [1] 2 3  All   Go Down
Author Topic: Tips on Filling Autobox  (Read 6541 times)
hp7166
  • Bridgend
« on: 22 January 2009, 09:12:29 »
Hi Guys
I am after some tips on filling the autobox
Hope you can help
Rob
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Tips on Filling Autobox
« Reply #1 on: 22 January 2009, 09:56:00 »
let the car warm up, leave it running, jack drivers side up, undo the bolt on the gearbox, let the jack off so the car sits back on the floor level,. If oil starts to run out put the bolt back in its fine, if no oil comes put some in.
Here is the tricky part, if you have some sort of bottle you can put a tube in great, I use a small hand pump with pipes each end  :y
hp7166
  • Bridgend
« Reply #2 on: 22 January 2009, 10:26:23 »
Had the warning light this morning so if i need to top it up for now is it still the same process
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #3 on: 22 January 2009, 10:43:35 »
Yep, exactly the same.
Can you see if there's an obvious leak though?
  • Online Online
« Reply #4 on: 22 January 2009, 10:57:00 »
Which warning light? There's no low level alarm/light on the gearbox.  :-/
MutantCav
  • Gainsborough
« Reply #5 on: 22 January 2009, 11:05:52 »
handy way to fill if needed is to run a tube from the filler hole with a funnel other end and pour the fluid in to the funnel...or get the atf from halfords...the bottle has an extendable tube on the bottle so you can just shove it in the hole and squeeze the bottle...although still easier to use a tube and funnel as you dont need to be under the car without a jack to give you the room needed lol
hp7166
  • Bridgend
« Reply #6 on: 22 January 2009, 11:26:09 »
Sorry the warning was on the screen on the dash
MutantCav
  • Gainsborough
« Reply #7 on: 22 January 2009, 11:27:23 »
What was the warning?? As said,no warning message for gearbox fluid low...
hp7166
  • Bridgend
« Reply #8 on: 22 January 2009, 11:31:25 »
Came up and Said Automatic Gearbox
  • Online Online
« Reply #9 on: 22 January 2009, 11:34:22 »
It's telling you there's a fault, not neccessarily low fluid. The car needs the code read to see what's upsetting the g/box. :y It could be anything .....   :-/
hp7166
  • Bridgend
« Reply #10 on: 22 January 2009, 11:36:55 »
ahh, does anyone know anywhere in Wales to get this done
hp7166
  • Bridgend
« Reply #11 on: 22 January 2009, 11:48:14 »
Is it a Tech 2 i need for the gearbox
ians
  • Reading
« Reply #12 on: 22 January 2009, 14:04:50 »
Still worth topping up as soon as you can - will not do any harm.
hp7166
  • Bridgend
« Reply #13 on: 22 January 2009, 15:27:16 »
yep my job for the weekend me thinks
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #14 on: 22 January 2009, 16:49:52 »
If you can get hold of a cheap pump up garden sprayer you will save yourself a lot of mess.
Just fill with ATF, remove the spray nozzle, pump up and fire into the filler hole.
TuBy's new whipping boy.
Pages: [1] 2 3  All   Go Up
