Pages: 1 [2] 3  All   Go Down
Author Topic: Tips on Filling Autobox  (Read 6525 times)
Re: Tips on Filling Autobox
« Reply #15 on: 22 January 2009, 16:52:02 »
Came up and Said Automatic Gearbox
What sort of milage has the car done?
hp7166
  • Bridgend
« Reply #16 on: 22 January 2009, 18:31:18 »
153,000
« Reply #17 on: 22 January 2009, 20:54:29 »
Diesels produce a lot of torque which the AR25 gearbox struggles to cope with. TheBoy (diesel owner) recons the autobox will be buggered by IIRC 130,000 miles :(
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #18 on: 22 January 2009, 20:57:16 »
I know where there is a good AR35 gearbox too  ;D ;)
hp7166
  • Bridgend
« Reply #19 on: 22 January 2009, 22:06:30 »
would love to change the gearbox just havnt got a clue how to
serek
  • huntingdon
    • 3.2 mv6
« Reply #20 on: 22 January 2009, 22:14:51 »
is 2 men job ,and very hard to put back if you dont have propo ramps
gearbox is around 50-60 kg
« Reply #21 on: 22 January 2009, 22:17:31 »
Im sure if you cross Loo-Knees palm with silver he will fit it for you :)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #22 on: 22 January 2009, 22:20:05 »
But what about the gearbox??? ;D
TuBy's new whipping boy.
Omega Pixie
  • Yorkshire
« Reply #23 on: 23 January 2009, 10:28:16 »
I brought a syringe holds 250ml and has a tube that just fits the gear box hole put tube in new atf suck it up and syring it into box.
« Reply #24 on: 23 January 2009, 10:32:05 »
I know a member on here got a windscreen washer bottle with a built in motor, filled the washer bottle with gearbox oil and connected the pump up, great idea ;)
« Reply #25 on: 23 January 2009, 10:36:33 »
It wouldn't take long if you used the headlamp washer pump!  :-?  :y  :y
« Reply #26 on: 23 January 2009, 10:40:45 »
Hmmm, I wonder how many litres an Omega washer bottle holds ;D
« Reply #27 on: 23 January 2009, 11:41:34 »
I got a cheap "killaspray" type device from Aldi / Lidl (7 or 8 quid IIRC).
Remove the metal lance / nozzle and replace with a length of 8mm copper tube bent into a "hook" at the end. Hook it over the filler hole and start filling!
ATF is quite a bit more viscous than water so it doesn't flow desperately fast. I would imagine a washer pump probably "grunts a bit" trying to pump it, but if it does the job...
hp7166
  • Bridgend
« Reply #28 on: 24 January 2009, 15:47:09 »
Ok
I have just tired to get into the box to fill it and there is no bolt on the box but a bolt with no sides and a hole in the middle
Very Strange, took it to a garage and they said it was a sealed unit and could not be done
« Reply #29 on: 25 January 2009, 09:51:56 »
ahh, does anyone know anywhere in Wales to get this done
Wales is a big place.....can you be more specific?
Pages: 1 [2] 3  All   Go Up
