Author Topic: Few Q's, sparks, clutch and cats  (Read 1948 times)
GmasterT
  • Cambridge
  • does that drifting thing...
« on: 27 January 2009, 13:44:28 »
OK, I still have the 0704 error, Clutch switch malfunction... Its a manual without cruise, so I cant see what or why?! (Any ideas?)
Easy one, Which bank are cyls, 1,3 & 5
And lastly, is there any way of getting the lambda plugs muddled underneath?
Cheers!  :y
Re: Few Q's, sparks, clutch and cats
« Reply #1 on: 27 January 2009, 14:05:52 »
I can answer the easy one, Drivers side ;)
GmasterT
  • Cambridge
« Reply #2 on: 27 January 2009, 17:02:42 »
Oh good, the easy to change side :D
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #3 on: 27 January 2009, 18:45:55 »
Could be Probably am talking codswallop, but there might be a connector just so the ECU knows what's what with the clutch - have a look for any loose wires around the pedal box, maybe?
GmasterT
  • Cambridge
« Reply #4 on: 28 January 2009, 09:52:56 »
Ummm, interesting, will have to look into the clutch thing as I had the error before changing the clutch and hoped it would have gone!
The missfire appears to be oil in the plug wells  >:( Any easy fixes?!  :D
hotel21
  • The Kingdom of Fife
« Reply #5 on: 28 January 2009, 10:05:30 »
Oil in the plugwells is the usual indicator for failing cam cover gaskets.  The oil builds up and breaks down the insulation of the leads and causes misfires.  Once cleaned/repaired/dried out, misfire may well go but may also require lead replacement....
kevpuk
  • Poole
« Reply #6 on: 28 January 2009, 11:00:49 »
Yep, this is me too.....James came to do the cambelt and service and discovered oil in 2-4-6 (Boo !) and so have just got the cam cover gasket done.....new plugs in and mis-fired slightly since at low revs. Grabbed new leads as old ones were pretty sh1te from sitting in hot oil and will be replacing at weekend.....
« Reply #7 on: 28 January 2009, 12:05:31 »
Possibly has a clutch switch fitted despite not having cruise....the clutch switch on the drive by wire cars connects directly to the engine ecu....
GmasterT
  • Cambridge
« Reply #8 on: 28 January 2009, 12:12:18 »
Ummm...
I cleaned everything out last night which this morning lasted about 10mins! May need to redo the plugs but they looked ok and are less than 2k miles old. Saldly I don't have leads but a coil pack (also cleaned up last night)... Is the cam cover gasket hard to change?
Marks, I will have a look when my knees wont get so wet! Odd thing is it never did it before... cheers  :y
« Reply #9 on: 28 January 2009, 12:15:03 »
I think the key thing is that its un-related to what you have worked on (the switch is on the pedal!)
GmasterT
  • Cambridge
« Reply #10 on: 28 January 2009, 12:22:06 »
Fair enough, cheers Mark  :y (I dont think its affecting much tbh and the engine light would still be on thanks to the cat efficency annoyance!)
As for the miss, I was supposed to be drifting on saturday, may try and whip off/change the rocker cover gasket on that side one evening if I can get the bits, hope the coilpack is ok (although Id have thought it would have thrown an erro code at me if a problem)
Mark, where have your pics gone in your ever so helpful guide?!  :D  ;D (http://www.omegaowners.com/forum/YaBB.pl?num=1152564281)
