Author Topic: fuel pump  (Read 1398 times)
sadman43
  • Northumberland
fuel pump
« on: 28 January 2009, 22:12:26 »
Hi all i`ve been told i need a new fuel pump and have been told it`l cost me around £700 as it is a difficult job and also will need to be programmed once fitted. is this true i though it would pretty straight foward to fit through the floor of the boot. any help would be welcome.
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: fuel pump
« Reply #1 on: 28 January 2009, 22:24:15 »
If you update your profile with car details i am sure someone will be able to advise.
You can buy a whole car for 700, so ask the breakers on the forum as they might have the part you need
MutantCav
  • Gainsborough
Re: fuel pump
« Reply #2 on: 28 January 2009, 22:27:59 »
Fuel pump (I believe but could well be wrong!) is in the fuel tank...
Presumably if you get a second hand fueltank/pump it wouldnt need reprogramming and will cost a LOT less than £700 even if it needs delivering and you could fit it yourself most likely  :y
Got one here depending upon what car you have...
sadman43
  • Northumberland
Re: fuel pump
« Reply #3 on: 28 January 2009, 22:30:55 »
I have a 1995 2.5TD elite
MutantCav
  • Gainsborough
Re: fuel pump
« Reply #4 on: 28 January 2009, 22:34:37 »
Ok well I only have a petrol one here...diesel one will most likely be different and may be located differently, someone will know  :y
philhoward
  • Staffs
  • Love the engines, so put one in something else..
Re: fuel pump
« Reply #5 on: 28 January 2009, 22:42:23 »
I'm guessing we're on about the pump that lives on the engine...in which its normal name is the injection pump.
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
sadman43
  • Northumberland
Re: fuel pump
« Reply #6 on: 28 January 2009, 22:56:12 »
yeah i think on reflection of the price iv`e been quoted it is the one the under the bonnet. I`m having loads of bother starting it up from cold, i`ve had the heater plugs changed and it`s still the same. it turns over no probsand takes ages to start but somtimes refuses to come to life.
MutantCav
  • Gainsborough
Re: fuel pump
« Reply #7 on: 29 January 2009, 08:25:14 »
I dont know much about diesels, petrol fuel pumps in the tank...but I know you could get a second hand pump for a diesel for much less than £700!!
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: fuel pump
« Reply #8 on: 29 January 2009, 09:38:22 »
Your problem is the lift pump un the tank
Diesel is different from petrol version
Cost approx £112 new
Wear rubber gloves when fitting as you will have your hands in Diesel!
