Author Topic: Removing Adjustable Monroe Rear Shocks  (Read 1380 times)
MutantCav
  • Gainsborough
« on: 04 February 2009, 08:00:35 »
How do I remove the adjustable Monroe rear shocks?? Its on an estate :y
« Last Edit: 04 February 2009, 08:00:54 by ShieldOfSteel »
Omegatoy
  • UK
Re: Removing Adjustable Monroe Rear Shocks
« Reply #1 on: 04 February 2009, 08:12:27 »
same as normal undo top and bottom conections, unclip/remove air pipe :y
MutantCav
  • Gainsborough
« Reply #2 on: 04 February 2009, 08:16:00 »
Thats assuming I have ever removed a shock absorber before...I havent lol
« Reply #3 on: 04 February 2009, 08:21:31 »
You may not get them off in one piece :(
When I needed to drop the shocks to replace the springs, the bottom seemed welded on, no way that was gonna pop off without shredding the rubber.
« Last Edit: 04 February 2009, 08:21:49 by jimbob »
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #4 on: 04 February 2009, 11:16:35 »
That's because the inner sleeve is dowelled into a recess in the trailing link. It ensures a robust fit between the shocker lower mount/trailing link, and reduces the stress on the shocker lower bolt.
Agreed, it can be difficult to remove.
