Author Topic: TC Button not working...any ideas  (Read 1828 times)
Kumamoto
  • Mombasa, Kenya
    • Omega 2.2
« on: 05 February 2009, 15:58:10 »
My traction control button next to the gear stick is not working...if you press nothing appears on the dash to indicate TC is engaged.
On my previous 99 V6 omega, when i press the TC button it used to illuminate on the dashboard.
Also. if i did hit a slippery part of the road surface and the tires skid..the TC light used to illuminate briefly on the dashboard.
I have hit so many slippery surfaces with the current snow..nothing doing. Its not the end of the world, but i would like the feature working.
Any help will be appreciated.
Cheer
Sad
  • Dorset
    • VW Golf
Re: TC Button not working...any ideas
« Reply #1 on: 05 February 2009, 15:59:30 »
I thought the light came on permanently in the dash if the TC was disengaged?
bigtow
  • rochester kent
  • 2001 3.2 MV6 manual was 2.6 auto
    • x type 2,0d estate
« Reply #2 on: 05 February 2009, 16:00:08 »
silly question does it light up when you turn the ing on ?
2001 MV6 3.2 manual been converted from 2.6 auto
Welung666
« Reply #3 on: 05 February 2009, 16:00:51 »
Cheer
It's not next to the gearstick, it'll be on the dash :y
Welung666
« Reply #4 on: 05 February 2009, 16:02:31 »
Correct, if the light is off your TC is on :y If you hit the TC button the light will stay on all the time it's switched off.
Sad
  • Dorset
    • VW Golf
« Reply #5 on: 05 February 2009, 16:04:00 »
You're not confusing the 'snow mode' button with the TC are you Kumamoto?
The snow mode doesn't light up in the dash, the actual button lights up for that...
« Reply #6 on: 05 February 2009, 16:07:16 »
no personal experience with this but afaik
 tc abs and speedo all run off the same ecu. So if other functions are ok, maybe its on the way out, or the bulb has gone in the dash? Tc is fairly crude and can be a bit slow cutting in and out, as you sure its not working? See what others say to confirm this though...
mikemeega
  • swansea
« Reply #7 on: 05 February 2009, 16:07:30 »
The TC dash light comes on with ignition and goes off when engine is running...TC is then on
When you hit a slippery patch and wheels loose grip the dash light will illuminate and then go off
If you press TC switch on then you disengage TC and the dash light stays on continuesly.
« Reply #8 on: 05 February 2009, 16:09:11 »
you've all missed the point. 2.2 doesn't have TC ;)
it has snow mode on autogearbox, thats it.
Welung666
« Reply #9 on: 05 February 2009, 16:14:37 »
 ;D ;D ;D I hadn't even noticed his 'drives' DOH! That'll learn me to look  :-[ ;D
« Reply #10 on: 05 February 2009, 16:46:11 »
oh, i looked, didnt know the 2.2 didnt have it, on re reading should have twiged the"next to gear lever" comment.  :y  :y  :y
Kumamoto
  • Mombasa, Kenya
    • Omega 2.2
« Reply #11 on: 05 February 2009, 17:12:22 »
Thanks guys. Can't believe the car does have TC. All my previous miggys had TC,but then again they were V6's
« Reply #12 on: 05 February 2009, 18:29:51 »
A 4 pot doesn't have the bo110cks to break traction!  ;) :y :y :y
« Reply #13 on: 05 February 2009, 18:37:32 »
Only the v6 has TC.  The 4 cylinders (petrol or diesel) and the 6 cylinder diesel don't have/need it :)
Page created in 0.028 seconds with 16 queries.
