Author Topic: help with a few computer messages and steering  (Read 1100 times)
tunes
  • essex
« on: 05 February 2009, 12:48:58 »
yep u guessed it, more probs lol
rite instead of seperate posts ill list here whats wrong and if anyone can help with any or all i would be massively appriciative
1.) check oil light warning on but oil is fine
2.) coolant level warning but again is fine
3.) slight play in steering wheel left and right and also if steering is rocked up and down like you were checking a wheel bearing
4.) can hear rear suspension whooshing as i enter speed humps
5.) when engine is left running the engine management light comes on but if i rev it slightly or drive then light goes off and does not reappear until left on tickover for a while
many thanks in advance people  :)
« Last Edit: 06 February 2009, 02:00:49 by tunes »
IF I WANT TO GO IN A STRAIGHT LINE, IL BUY A FORD
ians
  • Reading
Re: i really am sorry to be a pain in the a##e
« Reply #1 on: 05 February 2009, 14:23:25 »
just a suggestion, but can you make the title more relevant? (Imagine if everyone had a similar thread title..)
It is well worth you doing a paperclip test (see the maintenance guide section) - that will tellk you if there are fault codes stored (which may tell you why the EML light is coming on).
Check oil light is probably a faulty level sensor - it should come on when the oil level is roughly half way between the marks on the dipstick.
Check coolant may be a sticking float inside the expansion tank,  or a failed sensor on the bottom.  You can buy a new tank (sensor is integrated) if so.
Are there any signs of leaking suspension struts?
Ian
tunes
  • essex
Re: help with a few computer messages and steering
« Reply #2 on: 06 February 2009, 02:01:21 »
have changed now sorry
what about steering wheel? do they have like a bearing inside column?
