Author Topic: Coolant level warning message  (Read 1134 times)
jimbobmccoy
  • outer london
« on: 10 February 2009, 14:23:18 »
HI
Probably a simple answer to this.
Got a coolant level up with check on the display thingy.
Checked the level and it seemed ok, could do with changing, but i guess the sensor goes off level and not concentration or quality of liquid?
so is the message a precursor to something else, like the hbv going or something (or is that only on the v6's).
I dont think there's a leak as the level seems ok, so any help'd be appreciated.
Re: Coolant level warning message
« Reply #1 on: 10 February 2009, 14:29:04 »
if the level is fine, then the sensor is knackered.
Few jabs at the float with a stick may solve, as it may have gunged up a little.
If that doesnt sort it, then get a new tank of a breaker or vauxhall, about £30.
Your right, its not a clever sensor, just a float measuring water height.
« Reply #2 on: 10 February 2009, 15:04:37 »
prob float stuck as Jb says,
if you have to change the bottle, youll need to drain the fluid anyway, there is a drain plug bottom right of rad as you look at the engine bay.
Is it every 4 year to change the coolent?
jimbobmccoy
  • outer london
« Reply #3 on: 10 February 2009, 15:31:42 »
ta verily, i shall get poking tonight, and see what happens!!
apologies for the duplicate post, got internet issues at the mo.
ians
  • Reading
« Reply #4 on: 10 February 2009, 16:19:01 »
I aim to do mine every 2 years Chris, given its just a tenner for a can of antifreeze.
bighed
  • Shropshire
« Reply #5 on: 10 February 2009, 17:14:56 »
Funny, mine did exactly the same while driving yesterday. i sh1t it and pulled over only to find the coolant a lovely orange colour and bang on the mark. Im going to check the sensor is plugged in properly first after having work done a couple of weeks ago i might not of plugged it back in properly.  :y
« Last Edit: 10 February 2009, 17:15:17 by bighed »
« Reply #6 on: 11 February 2009, 07:46:21 »
Often fails due to KHMS
when filling the bottle, many people arent accurate and slosh some over the side, which runs down and attacks the sensor from the bottom.
