Author Topic: Fault code  (Read 1470 times)
TaxiManDan
  • Cheltenham
Fault code
« on: 09 February 2009, 18:43:39 »
Hi ran a fault code reader on my omega todays as the little orange car with the spanner keeps coming on and off and i got the code p1555, can anyone pls help me from what i can tell its to do with mass airflow sensor but i changed that about 20k ago, any ideas
thanks
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
Re: Fault code
« Reply #1 on: 09 February 2009, 19:17:56 »
Try here  :y :y
http://www.omegaowners.com/forum/YaBB.pl?num=1197277610
P1555   Throttle Position Sensor (TPS) Load Signal not Plausible with Engine Load
« Last Edit: 09 February 2009, 19:18:49 by Mark38 »
TaxiManDan
  • Cheltenham
Re: Fault code
« Reply #2 on: 09 February 2009, 19:33:28 »
ok thanks do u know where the sensor is located
Proz
Re: Fault code
« Reply #3 on: 09 February 2009, 19:44:55 »
Not 100% sure ... would think near the pedal thereabouts ....but im sure someone will be along shortly who does  :y
Jan Suhr
  • Nyköping, Sweden
    • 2 Omega Caravans 3.2 V6
Re: Fault code
« Reply #4 on: 12 February 2009, 20:14:33 »
The sensor is on the throttlehouse on top of the intakemanifold.
I have the same fault.
Jan
Jan Suhr
Stockholm, Sweden
www.protouring.se
Jan Suhr
  • Nyköping, Sweden
Re: Fault code
« Reply #5 on: 12 February 2009, 20:21:05 »
I have a vacuumproblem and I believe this is related.
The ECU calculates the engine load from the MAP reading and the MAF reading and the electronic throttle is adjusted to balance the air/fuel to the load.
If there is a vacuumleak the MAP reading gets screwed and the calculation is faulty.
Jan
Jan Suhr
Stockholm, Sweden
www.protouring.se
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Fault code
« Reply #6 on: 12 February 2009, 22:15:51 »
I'm sure i had same code along with a few others and after being checked by TB i replaced the throttle body (not cheap) Might I suggest a trip to an admin who could help you with a tech 2 read and potentially save you money
« Last Edit: 12 February 2009, 22:18:28 by radar »
