Author Topic: my engine keeps cutting out  (Read 3788 times)
astonmartin
  • southeast london
« on: 07 February 2009, 16:49:58 »
hi i am having a bit of a problem
as the car gets hot it cuts out it started when i was coming back from bluewater on the a2 as i came to the roundabout it just stopped put it in to n and started again it did it about 3 times before i got back home
i  believed it was idle control vale as the chip is missing but it has started to stop when it gets hot if it is just sitting or driving so it may not be the i,c,v  anyone know if there is a common problem or if i am just unlucky .
i have put it on the computer and said it was the chrank sensor  but don't know i have bin told sometimes the computer can be wrong
please help :'(
Re: my engine keeps cutting out
« Reply #1 on: 07 February 2009, 16:58:03 »
What were the codes - 19 is crank sensor.
Cleaning the ICV with carb cleaner costs very little, doesn't take long and could well cure your problem - try it first!
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #2 on: 07 February 2009, 17:13:09 »
Classic crank sensor problem, a new one will cure it.
TuBy's new whipping boy.
astonmartin
  • southeast london
« Reply #3 on: 07 February 2009, 17:43:46 »
just one more thing can anyone tell me if the 3.0 v6 has i type of sensor or too mine is a 1998 s reg i have a part number from ebay 90485251 but it says it has a steel sump and mine has a alley one
iainb
  • West Midlands
« Reply #4 on: 07 February 2009, 17:54:00 »
Mine does the self same thing but only when very low on fuel.
MutantCav
  • Gainsborough
« Reply #5 on: 07 February 2009, 18:49:04 »
98 s reg will have an oval plug and be part number 90540743...
Part 90485251 is black Vauxhall sealant used for camcover gaskets!!
astonmartin
  • southeast london
« Reply #6 on: 07 February 2009, 22:17:58 »
have just ordered the part it was £35.02 think that was a good price
« Reply #7 on: 08 February 2009, 14:33:26 »
Hope you bought genuine VX part not pattern ;)
« Reply #8 on: 08 February 2009, 14:59:10 »
Its crank sensor symptoms.  Every v6 owner should carry a spare ;D
Your car could take 1 of 2 types, most likely the plastic type.
Stick to genuine GM for this part if possible.
astonmartin
  • southeast london
« Reply #9 on: 08 February 2009, 17:39:13 »
got it from vaux all parts on the net hope to get it by Tuesday it said it is a genuine part will post to say if it is when it comes
PS has anyone else got parts from them
« Last Edit: 08 February 2009, 17:42:10 by theflyingpasty@yah »
astonmartin
  • southeast london
« Reply #10 on: 11 February 2009, 12:14:28 »
got part the next working day look's ok having fitted today will post you how it go's
markfree
« Reply #11 on: 11 February 2009, 13:04:17 »
If its vauxhall parts warehouse (on ebay), yes I got a crank sensor from them and it works fine :y
astonmartin
  • southeast london
« Reply #12 on: 12 February 2009, 23:04:46 »
hi to all have put the part in and it is still cutting out but taking a longer time now anyone with any ideas welcome of what it could be now :'( :(
astonmartin
  • southeast london
« Reply #13 on: 15 February 2009, 14:22:53 »
still have the problem but now the computer is saying sensor is OK now anything else it could be
blue_dream
  • Wellingborough
« Reply #14 on: 15 February 2009, 14:36:49 »
Hi
    This sounds to me to be the air mass sencer in the trucking from the air filter, may be the fuse link is on the way out, usual signs may be engine hot but temp ok, fuel comsumtion a bit high if you can souce another to try first, they are expensive about 80.00 plus and i think their are two.
    See how you go  :)
