Author Topic: transmission warning light on  (Read 1465 times)
john6177
  • Near Manchester
« on: 17 February 2009, 14:10:19 »
hi everyone. not been on because car has been so reliable until now !!
I have the following problem. The transmission fault light is on and the car/spanner light is on. car goes into limp home mode when in drive but not in 1,2 or 3.
I have a 2.2 gls 2001 estate.
The following codes have been read
1. generic code - P0705 transmission range sensor A circuit (PRNDL)
2.Vauxhall code - 1700 transmission control module (TCM) service request signal.
I fear it may be the £250 selector switch but dont want to spend all that money if it is something a little cheaper. not been underneath yet.
any help or comment will be appreciated
Re: transmission warning light on
« Reply #1 on: 17 February 2009, 14:18:10 »
Are the lights on the gear lever display playing up :question
john6177
  • Near Manchester
« Reply #2 on: 17 February 2009, 14:21:32 »
all lights are on when in park and drive ok otherwise
« Reply #3 on: 17 February 2009, 14:24:29 »
Remove the selector switch from gearbox, dismantle give it a good clean (switch contact cleaner)  :y
john6177
  • Near Manchester
« Reply #4 on: 17 February 2009, 14:28:57 »
will try that tomorrow. didnt want to dismantle unless i had too
« Reply #5 on: 17 February 2009, 14:34:21 »
john6177
  • Near Manchester
« Reply #6 on: 17 February 2009, 17:16:00 »
have been underneath. i followed the instructions from the other thread. thankyou. turns out my switch is bust. two of the copper prong contacts have burned away. Ah well £250 trip to dealers. in the words of james may C**K.
markey mark
  • SLady bitshorpe north lincs
« Reply #7 on: 17 February 2009, 18:24:57 »
dont buy a new one matey i will sell you a checked second hand one for a lot less than a new one  :y
« Reply #8 on: 17 February 2009, 18:46:26 »
range switch = selector switch.
a known good 2nd hand one is fine
