Author Topic: Tc ?abs  (Read 2462 times)
Bourne
  • Essex
  • Stupid tiny glovebox !
Tc ?abs
« on: 17 February 2009, 20:35:17 »
Hi guys , Can anyone tell me if the traction control uses the abs sensors? Both lights have started coming on intermittently and I suspect the abs light is a dirty or faulty sensor.Hoping its also the reason for the tc light. :-?
Re: Tc ?abs
« Reply #1 on: 17 February 2009, 20:41:37 »
yes - but your problem is the ecu is buggered
Re: Tc ?abs
« Reply #2 on: 17 February 2009, 20:41:38 »
Whats your speedo doing ??? and maybe the power steering ??? Not saying it is this .. just saying it could be the begining....
http://www.omegaowners.com/forum/YaBB.pl?num=1152729807
If it is ... then 3 choices
Vx - £300-600
bba-reman (or other electronic repairer) £100-200
Scrappy - £50-£80 - but make sure you get the right one ...
DIY it is an absolute sod to do .. not technically hard .. bloody awkward !!!
Bourne
  • Essex
Re: Tc ?abs
« Reply #3 on: 17 February 2009, 20:47:18 »
No problems at all with speedo or power steering. I'll try the sensors first. If that doesn't work I'll try to source a good used ecu. Thanks for the tips. :'(
Re: Tc ?abs
« Reply #4 on: 17 February 2009, 21:04:20 »
a decent code reader may help before blowing cash on repairing ecu, but post 1998 are problematic
Bourne
  • Essex
Re: Tc ?abs
« Reply #5 on: 17 February 2009, 21:06:45 »
Wiil a code reader recognise a faulty sensor & which one it is?
Timbuk
  • Telford
  • owned a Datsun 120y once!
Re: Tc ?abs
« Reply #6 on: 17 February 2009, 21:08:41 »
you will be very lucky if its a dirty sensor and not the abs ecu
Re: Tc ?abs
« Reply #7 on: 17 February 2009, 21:08:54 »
a good code reader, generic ones won't.
al brown
  • alton, hants
    • Rusty 97 3l estate
Re: Tc ?abs
« Reply #8 on: 17 February 2009, 21:18:50 »
I had a bad earth on one of the rear light clusters and it caused abs/tc lights to come on sometimes. Cleaned all the contacts and it has been fine for the last 3 years
If it aint broken, you aint trying hard enough
MutantCav
  • Gainsborough
Re: Tc ?abs
« Reply #9 on: 17 February 2009, 22:17:46 »
Worth a go...but as said most likely ABS/TC ECU
iainb
  • West Midlands
Re: Tc ?abs
« Reply #10 on: 17 February 2009, 22:31:57 »
ABS / TC  lamp on, Speedo working
front wheel speed sensors are prime culprit,so clean the crud off the back plate of the brake disc ................with a power wash while cleaning the car.
MutantCav
  • Gainsborough
Re: Tc ?abs
« Reply #11 on: 17 February 2009, 22:41:19 »
I think he will want to get the car sorted sooner than 6 months time mate  ;D
dragonlord
  • luton
Re: Tc ?abs
« Reply #12 on: 18 February 2009, 08:39:48 »
good luck m8
it will mostlikly the ECU , I have had same troble this week iv got the caved up finggers and brused knuckels to prove it.
just waiting for the corurer from BBA reman to pick it up
For the help of others trying to get one out I found a bit of an easyer way
than in guide
if theres a couple of you
follow the guide as normal bat, fuse box, wiring, top coolent hose and pas resvour removed
now undo the two nuts eather side of the abs hydrolic unit
theres a plate over the one on the enging side, bend that back a bit to clear bolt
watch you dont lose the bolts/ studs the just push in the side of the unit in rubber bungs
now you can lift the whole abs pump up with ECU still attached
just unclip the 3 break lines from the plastic clip on bulkhead
now you can lift the whole  unit the pipes are quit flexable
the flex a lot more than you would think with out damage
 but dont go to mad bending them
now one of you can lift pump and other one can undo bolts
and it comes out far easyer doing like this.
and even more inportaintly it will be easyer to refit the 6 t20 bolts this way
as I was able to basicly life pump up enoutgh for you to unscrew all six bolts with ease.
MutantCav
  • Gainsborough
Re: Tc ?abs
« Reply #13 on: 18 February 2009, 09:16:30 »
This does indeed work (its what I have done before although mine are going to the breakers yard after) although not recommended to do more than once or twice in its life...thankfully you shouldnt have to!  :y
dragonlord
  • luton
Re: Tc ?abs
« Reply #14 on: 18 February 2009, 10:50:40 »
ill second that I shure do hope I dont need doing again in a hurry.
