Author Topic: saab 3.0v6 turbo  (Read 2574 times)
paulsmv6
saab 3.0v6 turbo
« on: 23 February 2009, 13:06:17 »
hi there im new to this site and was wondering if any1 had any hints or advice about fitting a gm saab 3.0v6turbo engine to my mv6 thanks :y
    • 530D M Sport, 330i Coupe
Re: saab 3.0v6 turbo
« Reply #1 on: 23 February 2009, 13:29:49 »
Might be a bit of a problem in the manifold department as the Saab has the V6 mounted transversly
Welung666
« Reply #2 on: 23 February 2009, 13:33:12 »
Is it the same block as the Y/X30's?
paulsmv6
« Reply #3 on: 23 February 2009, 13:39:58 »
its out of a 1998 to 2000 model saab if that helps :y
paulsmv6
« Reply #4 on: 23 February 2009, 13:41:09 »
wud it b a case of fabricating the manifold to fit. thanks :y
« Reply #5 on: 23 February 2009, 14:00:22 »
It's been a topic of contention this week
http://www.omegaowners.com/forum/YaBB.pl?virboard=Newbies;num=1209458172
woodsy_mv6
  • West Sussex
« Reply #6 on: 24 February 2009, 14:54:44 »
Remember that the turbo is integrated into the manifold on these :y
From the moment I picked up your book until I laid it down, I was convulsed with laughter. Some day I intend reading it.
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #7 on: 24 February 2009, 23:15:46 »
theres no point doing this engine swap, the naturally aspirated version of this engine is flat as a fart (about 170bhp and slightly less torque than the omega engine) and then the turbo engine gets the same 200bhp with 40/50nm more torque so for the price of the engine, ripping the old one out and putting the saab lump in i dont think it's really worth it imho!
V8!!!!
woodsy_mv6
  • West Sussex
« Reply #8 on: 25 February 2009, 17:58:16 »
n/a engine as found in the 9000s makes the same 207 bhp and 199 lb/ft as the Omegas.
The only reason the turbo 9-5 V6 makes a mere 200, is due to the lowered compression. As stated though, more torque is your reward, and a modified block means it's less inclined to lunch the bottom end if further torque is extracted :y
ngrainqey
  • rotherham
« Reply #9 on: 25 February 2009, 18:06:47 »
afaik the 9000 v6 is actually a 2.5....also if you go on the saab forums they'll slate the 3.0 because it's like a wet fart for a turbo v6
V8!!!!
woodsy_mv6
  • West Sussex
« Reply #10 on: 25 February 2009, 18:40:16 »
No. The 9-3 came with a 2.5, but also didn't come initially with the full blown 2.3 due to the fact that the block had to be mounted at quite an angle.
The n/a 3.0 was most commonly found in the 4dr Griffins, (one of the the fewest and furthest between models at that)
Whilst Saab made the X30XE robust enough to cope with the modifications they made to it, that couldn't work miracles.
With your wild stereotypical Scandinavian 4-pots to hand, the V6 would seem odd choice to mod.........for Saab owners ;)
« Last Edit: 25 February 2009, 18:43:47 by woodsy_mv6 »
ngrainqey
  • rotherham
« Reply #11 on: 25 February 2009, 19:04:29 »
are you on about the 9000 wen you say 3.0 griffith?
the later 3.0 on the 9-5 is pants imo-it's got good torque but for a turbo 3.0 there's no point when you can get the same bhp without the turbo, if he's going for a saab lump then the v6 really isnt the best option to play with...or be a nutter and get a volvo 850R lump which will happily go upto 590 bhp if you have the money lol!
V8!!!!
