Author Topic: Paperclip test results  (Read 4307 times)
AndyVXR300
« on: 26 February 2009, 14:33:34 »
Hi, i'm stuck  i dont really understand the error codes from doing the paperclip test so i have posted the results on the video below, If anyone understands how these work could you please post the results as you see them.... thanks for your help !! Andy...
http://s684.photobucket.com/albums/vv210/andybiggsuk/?action=view&current=Movie.flv
WWW.VXRONLINE.CO.UK
Christian
  • Shropshire
Re: Paperclip test results
« Reply #1 on: 26 February 2009, 14:37:03 »
First was a 12
second a 19
unsure about 3rd!
Nope i dont doo Sheep!
« Reply #2 on: 26 February 2009, 14:38:31 »
12 - start of errors
19 - crank sensor - change it now!
there is another one but didnt get that, but that 19 will likely be the improtant one
AndyVXR300
« Reply #3 on: 26 February 2009, 14:41:54 »
Ok is the crank sensor pretty much a diy job or is it best to get the dealer to do it ??
WWW.VXRONLINE.CO.UK
« Reply #4 on: 26 February 2009, 14:42:46 »
edit  :
12 - start
19 - crank sensor
57 -
« Reply #5 on: 26 February 2009, 14:46:51 »
57 is Idle Air Control Voltage Low
which I think is often logged with a crank sensort fault.
Easy enough to change, sure it is in the maint guiod on how to best route the new cable away from hot bits
AndyVXR300
« Reply #6 on: 26 February 2009, 14:47:40 »
Just had a PM to say 19 may show up if the engine was not running during the test ??????
WWW.VXRONLINE.CO.UK
« Reply #7 on: 26 February 2009, 14:48:25 »
No, 19 is a stored incorrect crank signal
31 is engine not running.
any 19 is generally an indicator that you WILL breakdown at some inopportune moment.
I think however, there is one person on here who has a 19 that they can just not get rid off, and doesnt cause any problems, but that is the exception not the rule.
« Last Edit: 26 February 2009, 14:49:35 by jimbob »
« Reply #8 on: 26 February 2009, 14:49:33 »
12
19
57
129
3x (didn't get it before start started)
« Reply #9 on: 26 February 2009, 14:50:10 »
Absolutely correct.
AndyVXR300
« Reply #10 on: 26 February 2009, 16:09:06 »
ordered a new crankshaft sensor today £55 + Vat so ill fit it in the morning............. Thanks Guys for your help on the Error codes.
WWW.VXRONLINE.CO.UK
vauxfan2k
  • Western Isles
« Reply #11 on: 26 February 2009, 17:31:28 »
I have had code 19 on my elite for 3 years, only when I do the paperclip test tho, (enging running), if I check for codes using my reader, i dont get any.
« Reply #12 on: 26 February 2009, 18:12:01 »
Hmm... I've had a code 19 for about 7 months now and can't get rid of it. No problems though as I fitted a new sensor when it first started playing up and stored the code :y :y :y
« Reply #13 on: 26 February 2009, 18:21:45 »
Have you tried using a code reader to delete it?
« Reply #14 on: 26 February 2009, 22:10:32 »
When I was at Kevins we couldn't even get the tech 2 to comunicate with the engine ecu... Having thought about it I have a feeling the diagnostic wire isn't connected at the radio, which I believe is on the same line.
Was really hoping to have another go when I've checked behind the stereo
Page created in 0.028 seconds with 20 queries.
