Author Topic: ommision light  (Read 1486 times)
v6
ommision light
« on: 27 February 2009, 19:00:16 »
 :question my ommision light on my omega has come on just after i bought the car. i had it turned off by a garage but it has come on again.can anyone tell me why?
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
Re: ommision light
« Reply #1 on: 27 February 2009, 19:15:01 »
This is a prob with the 2.6 and 3.2 as they have 2 pre cats and also 2 pre cat o2 sensors.
It is these that are setting off the light . If you have an emisions test you will find that you are Fine so don,t think the cats are on there way out.
I and other members have had the same thing and the best way around it is to move the 2nd set of 02 sensors behind the main cats.This will give the gass an a 2nd clean before the  02,s pick up the reading. did this with mine and has been fine since.
Hope that makes some sence and helps. :y
Steve
Also this may help
 http://www.omegaowners.com/forum/YaBB.pl?num=1223977027
« Last Edit: 27 February 2009, 19:16:46 by SP_3.2 »
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: ommision light
« Reply #2 on: 27 February 2009, 19:29:54 »
Sounds like it's forgotten something! ;D
v6
Re: ommision light
« Reply #3 on: 27 February 2009, 19:38:39 »
i have noticed the sensors you are talking about but i dont quite understand exactly what you mean so could you explain again  :-/
SP_3.2
  • Leicester
Re: ommision light
« Reply #4 on: 27 February 2009, 21:29:09 »
No Probs
http://www.omegaowners.com/forum/YaBB.pl?num=1214690650/15
this may help and look towards the bottom of the post at the pics
And this is how i have set mine up ( as you can see they are now behind the bigger main cats.
http://i400.photobucket.com/albums/pp84/steveparke/P1300155.jpg
http://i400.photobucket.com/albums/pp84/steveparke/P1300156.jpg
HTH
steve
Grottblatt
  • Aylesbury
Re: ommision light
« Reply #5 on: 27 February 2009, 21:38:39 »
I agree with SP_3.2. I regularly get the light on, but after a good long (~100+ miles) it goes out. It has done this since I bought it but has always passed its MOT test without any problems.
Why is dyslexia such a difficult word to spell?
v6
Re: ommision light
« Reply #6 on: 28 February 2009, 17:25:16 »
thanks for the pics i will have a look on monday at work :)
Re: ommision light
« Reply #7 on: 28 February 2009, 20:07:26 »
Stick your location in your profile .. there might be someone near with a code reader / resetter that can help  :)
In the mean time .. read here ...
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
If you get an 0420 or an 0430 then its the precat problem ..
« Last Edit: 28 February 2009, 20:09:02 by entwood »
