Author Topic: TD Paperclip test results  (Read 2077 times)
platty
  • Cambridge
    • BMW 530d Sport
« on: 04 March 2009, 14:28:51 »
Just done the paperclip test on the TD for the first time to:
a) to see if it worked
b) to see if it brought up any particular faults
Well, it did work and I got the following sequence:
12  12  12
19  19  19
95  95  95
12  12  12
..... repeat again
12 is a mystery as it doesn't list this code on TB's index. Any ideas?
19 is Incorrect RPM Signal - is this because the engine is off?
95 is Output Amplifier Defect - what does this mean - anyone?
Any help would be greatly appreciated!  :y
« Last Edit: 04 March 2009, 15:08:33 by platty »
Loch View
  • Dumbarton, Scotland
Re: TD Paperclip test results
« Reply #1 on: 04 March 2009, 14:30:05 »
12 is start of frequence I thought
[size=14]Deja Moo: The feeling you've heard this Bullsh1t before![/color][/b][/size]
platty
  • Cambridge
    • BMW 530d Sport
« Reply #2 on: 04 March 2009, 14:34:40 »
Right you are - I didn't spot that note in the instructions! Thanks  :y
No ideas on 95 though?
Loch View
« Reply #3 on: 04 March 2009, 14:35:41 »
no, sorry but I'm sure someone else will :y
« Reply #4 on: 04 March 2009, 14:52:45 »
19 is duff crank sensor and your problem !
platty
  • Cambridge
    • BMW 530d Sport
« Reply #5 on: 04 March 2009, 15:08:07 »
I know this is the case on the 2.5V6 but wasn't sure if the same applied for the TD. Oh, well I had better look into that then  :(
« Reply #6 on: 04 March 2009, 20:04:05 »
19 is still a crank sensor issue on TD.  Generally reliable though.  Check its fully seated, and the connector on the sensor is fully home.
platty
  • Cambridge
    • BMW 530d Sport
« Reply #7 on: 05 March 2009, 08:34:24 »
You can probably guess what I am going to ask next - but where is the crank sensor on the TD? Ta :y
« Reply #8 on: 05 March 2009, 18:47:18 »
under the starter motor.  Intake off, may possibly have to take starter motor out.  Can get to it from underneath, but working blind...
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #9 on: 05 March 2009, 21:43:28 »
Check your 'in-box' Chris!
« Last Edit: 05 March 2009, 21:44:20 by Reliance505 »
