Author Topic: good news everyone  (Read 3269 times)
mick-1975
  • nottingham
good news everyone
« on: 07 March 2009, 18:07:54 »
  right then after my previous thread ,,
i know this is long but bide your time ! ;D
 i have got my car started and sounds sweet as u can imagine im very pleased  :y :y :y :y :y :y
 took a while to start but did kick in ,
  charged the  battery  and checked the earth straps and gave it a go and fired up she went .
    right then now for the bad news ,
  1 ,  oil leak on the breather from the sump
  2 ,  slight tapping noise .sounds from the bottom end as ear to sump ,
  i have put 15/40 oil in at the mo and going to run it a while then drain it while red hot to clean it out as water could still in places ,
  what grade of oil would you reccommend???? :y
 thanks ,
markey mark
  • SLady bitshorpe north lincs
Re: good news everyone
« Reply #1 on: 07 March 2009, 18:08:52 »
10/40 vaux semi syn  :y
mick-1975
  • nottingham
« Reply #2 on: 07 March 2009, 18:11:31 »
  daft question but how does the grade work with the thickness ?? :-[
markey mark
« Reply #3 on: 07 March 2009, 18:12:40 »
its hot n cold but carnt remember which way !! ::) ::)
VX1
  • Reading, Berkshire
« Reply #4 on: 07 March 2009, 18:12:41 »
Drain that goo out (15/40) as is no good for the mig engine at all it don't lik it. Replace with 10/40 which is recommended from vx. If you are getting a knocking noise from the botoom end that could be becuase you have pu 15/40 in on the other hand it could be th oil pump onit's way out. The tapping noise you are getting from the top end could be a hydraulic lifter rattling but will go quiet after a few minuetes. The oil leak could be the crankcase breather not done up enough. I am sure someone else will be along to say something else.
HTH
Paul :y
P.s Glad you got it going. What was it in the end?
Vx Trade club card holder
Halfords trade card holder
VX1
« Reply #5 on: 07 March 2009, 18:14:52 »
[/highlight]
I think its something like 10 is the thickness it is and the 40 is temp it is ok to as -40 i think. Someone else will be along soon to give accurate  info
Paul :y
P.s I need to typr quicker :-[
VX1
« Reply #6 on: 07 March 2009, 18:16:37 »
mick-1975
  • nottingham
« Reply #7 on: 07 March 2009, 18:20:34 »
HTH
Paul :y
  good question , i checked everything and gave it a whirl and she fired up took some time ,
  the oil def coming from breather tube  and tight , going to replace the gasket , , is 10/40  thicker than 15/40 ,  :y
   i took the rocker cover off after letting it run for a while and get to temp and found slight gundge still , so just wondering if water could be in some places ,
   going to use the oil in to flush it out !! :y
VX1
« Reply #8 on: 07 March 2009, 18:36:40 »
Yes 15/40 is thicker than 10/40. Did you check the crankcase breather tube was clear?
Paul :y
mick-1975
  • nottingham
« Reply #9 on: 07 March 2009, 18:39:35 »
Paul :y
  yes mate , cleaned everything out that needed to as full of crap ! :y
VX1
« Reply #10 on: 07 March 2009, 18:49:35 »
Paul :y
Did you use a new gasket on the breater tube that bolts on the crankcase at the back?
Paul  :y
mick-1975
  • nottingham
« Reply #11 on: 07 March 2009, 18:57:27 »
Paul :y
Paul  :y
    unfortunatly no ,  :-[ but wish i did now as its a bi*th to change with everything in place !! :y
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #12 on: 07 March 2009, 19:01:52 »
[/highlight]
Paul :y
I always thought the numbers related to the viscocity of the oil at operating and room temp. So 10/40 would be thinner than 15/40 at operating temp but the same when cold.  I could be mistaken though
VX1
« Reply #13 on: 07 March 2009, 19:04:52 »
[/highlight]
Paul :y
I can't quite remember either gaffers ::)
Paul :y
Omega man 2
« Reply #14 on: 07 March 2009, 19:06:00 »
Paul :y
Good thing to check that, its because of that little b*llocks that one of my conrods ended up over there somewhere >:(
