Author Topic: Cranky or Cammy?  (Read 2803 times)
Debs.
Cranky or Cammy?
« on: 24 February 2009, 14:24:19 »
Debs` `99 2.5 V6 'Pup-Mobile' was (most-unusually) reluctant to start this morning; it seemed to be "fighting the starter" and required frantic efforts to catch the 'firing' with my throttle foot....a symptom I know-well, as I had the same problem in my previous Miggy (a 2 Ltr. 16v) when the cam sensor failed.
I haven`t had time to break out the paperclip yet, but I`m assuming that when I do, it`s going to reveal a crank or cam sensor failure.....I am wondering if it is better to change them-both at once?
......and (approx.) how much would the two sensors cost, bought on a trade-club [size=9](that is; if I can persuade a kindly, 'nearby' OOF`er to let me use their T.C card.)[/size] ::)
Re: Cranky or Cammy?
« Reply #1 on: 24 February 2009, 14:38:11 »
Cam sensor, about £60 inc. vat. :'(
Crank sensor, about £70 inc. vat. early models, about £50 inc. vat. later models  :'( All TC prices.
« Reply #2 on: 24 February 2009, 14:46:38 »
Your welcome to my card, can either buy and post, or can meet up.
Can also use my diag tool if you want a play  ;)
I wouldnt bother replacing sensors which aren't reporting a fault, could just be introducing more unknowns.
Debs.
« Reply #3 on: 24 February 2009, 14:55:31 »
Yikes! :o
.....but, still-better than being off the road! ;)
Debs.
« Reply #4 on: 24 February 2009, 15:00:00 »
 :y Thanks so much for the kind offer Jimbob, that`d be so much appreciated; I`ll have a bit more time tomorrow so will break-out the 'paperclip' to see what`s what; then take it from there.....we`re long overdue a meet-up for a cup o`tea aren`t we? ;)
« Reply #5 on: 24 February 2009, 15:01:32 »
Definately, think about you every time we pass your 'area' thinking really should meet up.  :y
« Reply #6 on: 24 February 2009, 15:14:47 »
If it's a square plugged, metal bodied crank sensor (the more expensive one) I have one I purchased in error you can have for £55 :y :y :y
« Reply #7 on: 24 February 2009, 16:02:00 »
V6 cam sensor failure.....only seen them broken by the hand fisted amongst us.
« Reply #8 on: 24 February 2009, 19:07:38 »
As MDTM says, V6 cam sensors never fail.
Not convinced its crank sensor either, though I'm sure the paperclip will prove me wrong ;D
kris9128
« Reply #9 on: 24 February 2009, 19:49:51 »
i paid £56 for my crank sensor last march. from dealer no tc.  :y
« Reply #10 on: 24 February 2009, 19:53:57 »
Cheap type is £35 ish, more expensive £50 ish, ex vat, TC price (which I think is just trade price)
« Reply #11 on: 24 February 2009, 19:55:45 »
bugger, all gone up....
2.0 8v 90493864 £55.50 £49.96 £43.04
2.0 16v to 14194716 90458251 £55.50 £49.96 £43.04
2.0 16v from 14194717/31000001 9174621 £33.60 £30.29 £25.96
2.5 (early models) 90492006 £76.50 £68.85 £59.23
2.5 (later models) 90492061 £55.50 £49.96 £43.04
2.6/3.0/3.2 90540743 £49.70 £44.78 £38.38
2.0DTi/2.2DTi 90540188 £35.65 £32.09 £26.73
U25TD/X25TD  90487810 £80.00 £72.00 £61.97
« Reply #12 on: 24 February 2009, 20:26:21 »
Debs yours is likely to be oval plug, plastic end near oil filter - on TC I paid £42.80 + VAT recently for mine.  Hope that helps - part nş is 90492061
« Last Edit: 24 February 2009, 20:27:07 by dbug »
« Reply #13 on: 24 February 2009, 20:29:30 »
yep..no headache after :y
« Reply #14 on: 25 February 2009, 19:08:10 »
Did you manage to check for codes?
