Author Topic: Oil Filters - Paper element vs Metal can  (Read 1432 times)
DaveyDavey
« on: 13 March 2009, 12:14:25 »
Afternoon all,
According to the chap at VX parts I just spoke to (I've not stuck my head in to check) I will have the paper element filter on my car.
As I am going to be cleaning the breather system and changing the oil this weekend, I was wondering whether I should be considering a change over to the metal can filter at the same time.
Anyone know if there is any benefit to be gained??
TIA
Welung666
Re: Oil Filters - Paper element vs Metal can
« Reply #1 on: 13 March 2009, 12:17:08 »
6 and 2 3's really. IIRC the paper filters are cheaper :P
[edit]Not an easy swop over either[/edit]
« Last Edit: 13 March 2009, 12:18:06 by Welung666 »
DaveyDavey
« Reply #2 on: 13 March 2009, 12:30:25 »
Splendid, just the answer I like to hear.
I only asked as I recall seeing a conversion in the "how to" section a while back. Thought I ought to ask just in case, seeing as I was going to be fiddling with things anyway.
Ta muchly  :y
vauxmad
  • Oswestry, Shropshire
« Reply #3 on: 13 March 2009, 18:18:29 »
theres no performance difference as the paper one is just the same as changing an insides of a normal one so its only difference is its cheaper
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #4 on: 13 March 2009, 19:13:29 »
Unfortunately they're not.
93156954 oil filter 2.0/2.5/3.0 £4.19 retail £1.97 trade £1.22 TC
9192426 oil filter 2.6/3.2 £4.76 retail £4.05 trade £3.34 TC
all +VAT
Prices from the latest TC book.
TuBy's new whipping boy.
tomoco
  • leicester
« Reply #5 on: 13 March 2009, 21:27:52 »
People only usually swap over because the metal can type tends to get over tightened and damaged. Pigs to remove when in that state . Sometimes you have to go down the conversion route because you just about destroy the thing taking the cap off. My advice is if yours is in good order (use a 24 mm socket or spanner only) then keep things as they are mate. :y
