Author Topic: brake sensor  (Read 1245 times)
rikki_essex
  • essex
    • 2L gls estate with lpg 20
brake sensor
« on: 16 March 2009, 08:36:05 »
is there any way to turn the brake sensor off as i had the wheels off and the calipers then realised that they were the wrong ones without the sensor. so i had no choice to put them in but now there in i dont see the point in taking them off again and paying for a new set as they work. the only problem is the warning saying brake pad keeps coming up is there a way to turn it off?
regards Rik
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
Re: brake sensor
« Reply #1 on: 16 March 2009, 08:37:35 »
Only way I found was to unplug the sensor and bridge the plug with a short length of wire :y
Trade club card holder
Code scanner available
Re: brake sensor
« Reply #2 on: 16 March 2009, 09:14:28 »
be careful doing it that way, wire can rust into the connector, making the fix permanent.
The best way is to leave the old sensor attached, just cut and join those wires.  much 'safer'
alexandjen
  • The Silver Surfer
Re: brake sensor
« Reply #3 on: 16 March 2009, 09:17:16 »
Good point well made, but unfortunately I didn't have a sensor at all ::)
Re: brake sensor
« Reply #4 on: 16 March 2009, 10:52:31 »
be careful doing it that way, wire can rust into the connector,  ......
Copper wire doesn't rust.  ;)  ;) :y :y
Re: brake sensor
« Reply #5 on: 16 March 2009, 12:20:03 »
Paperclips do  :-[  ::)
Re: brake sensor
« Reply #6 on: 16 March 2009, 12:25:59 »
I'll find you a piece of stainless welding/filler rod, you can make your own non rusting version!  ;D  ;D  :y
