Author Topic: Screeching noice  (Read 1512 times)
Black Knight
  • York
Screeching noice
« on: 16 March 2009, 21:55:04 »
Still struggling to locate this screching noise. Its much worse when I opened the passenger window so I guess it coming from the NS.
Given in and gonna take it to the garage to diag tommorow, more money :'(
I did slip the car into neutral today whilst moving and the noise continued. Does the drive shaft stop spinning when you are coasting?
I'm still thinking it has something to do with the wheels/brakes though. Warped discs maybe?
Re: Screeching noice
« Reply #1 on: 16 March 2009, 22:00:05 »
Does the drive shaft stop spinning when you are coasting? ......
No.  ;)
You'd be able to feel warped discs when you braked, the pedal would pulse under your foot.
It could be a stone trapped between the disc & back plate  :-/  :-/
rob in gib
  • Plymouth
    • Jaguar S type 3.0
« Reply #2 on: 16 March 2009, 22:03:48 »
yes prop shaft will turn while coasting agree with andy sounds like a stone traped or heat shield touching prop shaft  :y :y
Just chilling in the sun. I wish back in the rain like everybody else
Tawfield
  • Berkshire
« Reply #3 on: 16 March 2009, 22:40:33 »
Could be a stone trapped in one of the disks,or and I had a noise from the clutch plate on the air con pump where it didnt release properly that was on my last mig a 2.0 ltr.
Black Knight
  • York
« Reply #4 on: 17 March 2009, 17:18:43 »
Close, but no biscuit!
There is a clip which sit against the brake pad, almost like a cross shape. That had snapped and a bit of it had wedged against the disc.
All sorted now and a big smile on my face :)
Tawfield
  • Berkshire
« Reply #5 on: 18 March 2009, 00:10:24 »
Good result then nice and simple.
