Author Topic: stupid question?(camcover o-rings)  (Read 1116 times)
« on: 18 March 2009, 13:42:48 »
The 16 little o-rings that seal the holes where the bolts go,presumably they go between the underside of the bolt and the camcover? there was no sign of any of these when I took the covers off,so Im a bit unsure! ::)
Re: stupid question?(camcover o-rings)
« Reply #1 on: 18 March 2009, 13:48:57 »
Yes.
Double check, as after time they go hard, and look like they are part of the camcover - they is a obvious indentation for them, if thats not there, use a small screwdriver to hook the old ones out
« Reply #2 on: 18 March 2009, 13:49:57 »
I shall have a look and report back. :y ;D
« Reply #3 on: 18 March 2009, 13:55:57 »
I think I might have found them,underside of camcover,like little bits of hard plastic rather than o-rings? :-/ ::)
« Reply #4 on: 18 March 2009, 14:03:15 »
If they are the size of your replacement o rings, thats them.  Come out looking like plastic washers...
« Reply #5 on: 18 March 2009, 14:05:34 »
 :y :ycheers,wasnt sure if I should dig them out as they didnt look much like the new o-rings,but I just tried 1 and it fits o.k. :y
« Reply #6 on: 18 March 2009, 14:08:21 »
Now get back out there, and finish the job ;D
« Reply #7 on: 18 March 2009, 15:24:56 »
 ;D ;D-o/s now back on,n/s cover cleaned up and ready to go back,time for a cup of tea and a bit of OOFing.not bothered if it gets finished before dark tbh,just taking my time (and getting interrupted regularly ::)). :y
want to spend as much time as it takes to clean the breathers properly while re-assembling as well.
There was so much oil in the plug wells,I reckon an American invasion of north Essex was imminent ::) ;D
« Last Edit: 18 March 2009, 15:27:23 by albitz »
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
« Reply #8 on: 18 March 2009, 16:35:08 »
If you're going to do one of them in daylight, I'd pick n/s! ;)
o/s alright in the dark.
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
« Reply #9 on: 18 March 2009, 19:06:27 »
Both sides done,plenum back on,just wires/pipes etc to finish off,but the smell of roast lamb brought me indoors at 5.30.will finish the odds &ends in the morning,thanks to The Boy for giving the right info just when it was needed. :y
