Author Topic: check coolant still on ?  (Read 1201 times)
Ken T
  • Stockport
« on: 17 March 2009, 18:15:52 »
The Check Coolant message came on recently, I topped up the water by about a pint or so, but the message still comes on ?. The engine temp seems about 4deg hotter than normal, about 90deg.  Where is the water sensor it uses ?.
Ken
pauldmackay
Re: check coolant still on ?
« Reply #1 on: 17 March 2009, 18:24:58 »
Sensor is part of the coolant resevoir bottle, check the wires.............not sure of any repairs that can be donje if you need to change the whole thing
« Reply #2 on: 17 March 2009, 18:33:06 »
Sensor is part of the coolant bottle which means the whole bottle has to be replaced if the sensor is caput :(
Ken T
  • Stockport
« Reply #3 on: 17 March 2009, 19:02:24 »
Thanks Guys, I'll go out with the meter and see whats happening.
Cheers Ken
gazsomega
  • midlands
    • 2.5 Opel estate
« Reply #4 on: 20 March 2009, 19:47:27 »
mine comes on all the time ive now bridge it as i check the coolant regular
Used  to have  two v6 and they roared
Now got 2.5 to Opel
« Reply #5 on: 20 March 2009, 21:49:49 »
Right up your street this one Ken
The bottle has a float inside that can get a bit gunked up....easily cleaned.
If this is ok, on the bottom is a connector, warm the area around this up (boiling water works well) and you can pull the full assembly out.
The sensor is nothing more than a read switch and I have seen a few with dry joints.
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
« Reply #6 on: 20 March 2009, 21:53:43 »
I've got two here that mis-report coolant level.  Both read fine on a continuity tester when off the car.  I guess the (reed?) switch gets lazy when in the same position for months.
I would strongly recommend removing the connector (underneath coolant header) and shorting with a bit of wire.  Then remember to check coolant the old-fashioned way.
New tank assy about 30GBP if I recall.  Don't waste time on a S/H unit.
« Last Edit: 20 March 2009, 21:54:55 by ChrisH174 »
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
Page created in 0.021 seconds with 16 queries.
