Author Topic: Outside temp reading  (Read 1260 times)
Phil.d
  • lancashire
« on: 19 March 2009, 20:10:52 »
Its just come on today so what will an f and a c in the display mean.I have read the owners manual and obviously theres a fault. If its the air temp sensor , where is that located and is it easy to replace. I've always liked vauxhalls but I think somewhere along the way they dont seem as good , had a vectra c sri , nowt but trouble.
Welung666
Re: Outside temp reading
« Reply #1 on: 19 March 2009, 21:05:53 »
As yours is a facelift it'll be behind the front grill :y
Phil.d
  • lancashire
« Reply #2 on: 19 March 2009, 22:50:21 »
thats sounds easy enough to get to. Would the sensor be the cause of the reading on the display?.Probably get one , they arn't that much to buy.
« Reply #3 on: 19 March 2009, 22:51:51 »
Before you change sensor trace wiring route and check for breaks or chaffing :y
Phil.d
  • lancashire
« Reply #4 on: 19 March 2009, 23:09:38 »
Ok I'll have a look around when I find it. Its a bit strange the reading coming on with no warning, been fine since I got the car. Just remembered , yesterday the reading when I turned on the ignition read about 65 c then came down.
Phil.d
  • lancashire
« Reply #5 on: 21 March 2009, 14:32:34 »
I replaced the sensor today and all is well. For the record the sensor is slap bang in the middle of the grill and to get to it , take the 3 plastic pins out underneath the flat section and within 5 mins its done.
