Author Topic: Exhaust too Noise  (Read 3570 times)
Daniel_uk
  • Bracknell
Exhaust too Noise
« on: 13 March 2009, 18:19:43 »
Hi im omega owner from 6 mths and i have the same problem fom begining driving omega.The exhaust system is very noise.I put new one GM but still wrrr wrrr from rear box.Please let me know if somebody know good quiet one. Some people  said BOSAL is great.Please Help Daniel   Omega b aut 2.0 16v saloon   Thanks   Cry Cry Cry
Re: Exhaust too Noise
« Reply #1 on: 13 March 2009, 22:45:34 »
i have nothing good to say about bosal, the packing/silencer material often falls out and blocks the system. As other members on here have found.
I am suprised the GM box is noisy. I wonder if another part of the system is at fault? Have you tried blocking/covering the exhaust with a rag and listen for leaks/noise from other areas. Is the mid section stock with no holes?
Daniel_uk
  • Bracknell
« Reply #2 on: 13 March 2009, 23:00:57 »
HI i try blocking exhaust is mayby little bit more quiet but i cant driving like that.I check all part its ok no holes nothing.
« Reply #3 on: 13 March 2009, 23:09:56 »
Very strange. GM exhausts are quiet. I wonder if the parts are correct? Maybe post a picture, hopefully a 4pot owner will see something amiss.
Daniel_uk
  • Bracknell
« Reply #4 on: 15 March 2009, 14:12:41 »
I dont know how to put picture but this is numbers on exhaust Back box.
 81726   028324 op 224 mayby somebody know that is corect for Omega 2.0 16v saloon petrol engine. ;)
jonathanh
  • coventry
« Reply #5 on: 15 March 2009, 14:18:56 »
I think about 18 months ago VX changed their supplier.  They are no longer the wriggly tin type boxes - just the usual can type things.  Not a quiet as the original
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #6 on: 15 March 2009, 15:32:46 »
Same here regarding Bosal .......
However, generally the GM exhausts are spot-on.
Why not get back to the stealers and get a replacement under warranty - again!
For aftermarket systems I fit Walker, and find them to be of excellent quality.
« Last Edit: 15 March 2009, 15:34:52 by Reliance505 »
Daniel_uk
  • Bracknell
« Reply #7 on: 15 March 2009, 21:59:23 »
Hi yeah but where to buy walker exhaust ? Thx
Seth
« Reply #8 on: 15 March 2009, 23:25:55 »
Most reputable motor factors stock them.
Insist on Walker when ordering, and don't accept anything else.
Alternatively, try an on-line search.
NickA
  • Cambridge
« Reply #9 on: 16 March 2009, 13:20:14 »
I had a Walkers exhaust fitted by National Tyres after rejecting 2 Timex exhausts that were way too noisy.
« Last Edit: 16 March 2009, 13:21:07 by NickA »
mathewst
  • Split, Croatia
    • v40
« Reply #10 on: 16 March 2009, 13:26:14 »
Are you sure the rear exhaust is the problem?
Try to chech the grilled part of the exhaust (don't know the exact name in english sorry) in the middle of the car towards the front. If it has even a small hole it produces a huge noise.
ians
  • Reading
« Reply #11 on: 16 March 2009, 15:26:30 »
Are you sure its not rattling against the heatshield above it?
Daniel_uk
  • Bracknell
« Reply #12 on: 16 March 2009, 17:12:34 »
im going tomorow to the garage check where the noise exact coming from but i check rear box when i look in pipe i can see other site( like binoculus) its normall ?
ians
  • Reading
« Reply #13 on: 16 March 2009, 18:29:37 »
is that with it on the car - Im surprised you can see through it..
binoculars - that suggests dual pipes - are you sure on a 2.0?
Daniel_uk
  • Bracknell
« Reply #14 on: 16 March 2009, 18:57:26 »
its only one pipe but i can see trough
