Author Topic: Headlight - Low Beam / FLD Vision  (Read 891 times)
« on: 24 March 2009, 15:55:31 »
Tis my turn  ;D
B3413  Present
( 0 )  Front Car Level Sensor, Signal High Input
So looks like the sensor will be present, any ideas on fixing this code?
Not been underneath to have a look yet.
  • Online Online
Re: Headlight - Low Beam / FLD Vision
« Reply #1 on: 24 March 2009, 16:00:39 »
Tis my turn  ;D
B3413  Present
I reckon you'll need a 'new' sensor ..... cured my fault message.  ;) About £50 for a new one.  :(
« Reply #2 on: 24 March 2009, 16:24:37 »
Well to start with check the sensor and wiring......and do as I did to your rear one and lube and exercise the ball joints.
It may be the control arm hs popped off.
And dont do it in the early hours whilst in the buff!
« Reply #3 on: 24 March 2009, 16:29:11 »
Cheers all
So its a good check and clean and hope for the best.
Failing that new one, these normally reliable enough for getting off a breaker or are new recommended.
As for working in the Buff, dunno what you mean  ::)
As if I would venture outside naked in the middle of the night  ::)
(saves getting your clothes dirty though  ;D)
I'm not shy  ;D
« Reply #4 on: 24 March 2009, 16:37:52 »
Yes, one from a breaker would be fine!
ians
  • Reading
« Reply #5 on: 24 March 2009, 17:15:12 »
  :o ::)
« Last Edit: 24 March 2009, 17:15:55 by ians »
