Author Topic: Horn Open Circuit  (Read 1468 times)
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
Horn Open Circuit
« on: 25 March 2009, 15:04:28 »
Whilst playing with Pc based diagnostics and looking in the alarm section it showed a fault saying  " 125 Horn Circuit Open " ... as far as i am aware it works fine .
Any ideas ?
Re: Horn Open Circuit
« Reply #1 on: 25 March 2009, 15:06:39 »
Was this against the alarm/central locking ECU?
Proz
« Reply #2 on: 25 March 2009, 15:09:53 »
It was in " anti theft warning " section .
« Reply #3 on: 25 March 2009, 15:13:04 »
So would relate to the horn or power sounder under the drivers scuttle
Proz
« Reply #4 on: 25 March 2009, 15:15:32 »
I know the horn works fine ... is there a away of setting of the power sounder deliberatly  :y
« Reply #5 on: 25 March 2009, 15:18:34 »
Lol, the alarm has the power sounder AND a hor....the horn is seperate from the horns on the steering wheel
Proz
« Reply #6 on: 25 March 2009, 15:22:00 »
Lol yes i understand the horn is separate  ::).... how can i set of the alarm to check the power sounder ... would opening with the key rather than the fob do it  :y
« Reply #7 on: 25 March 2009, 17:12:00 »
Disconnect the battery.
Really.
It is there simply to sound if a thief disconnects the battery to stop the "normal" horn going.
If you wish to disconnect the battery WITHOUT the alarm sounder going offf, you must do so within 20 seconds of turning the ignition off.
