Author Topic: Flashing.  (Read 1161 times)
Black Knight
  • York
Flashing.
« on: 27 March 2009, 13:06:51 »
Is it bad?
If the dipped beam (HID) is already on, the flash would only engage the normal type bulb full beam.
But if the lights are off and I flash, do both the Dipped HID and standard lamp full beam both come on?
If so, does this damage a HID system? DOn't know much about them but i Think it's the initial switch on that uses the most power??
Re: Flashing.
« Reply #1 on: 27 March 2009, 13:25:19 »
Flash ONLY works on main beam, the HID will not fire fast enough, if you watch a HID on switch on it takes about 3-5 seconds to reach full intensity. Also, the more a HID is turned on/off the shorter the life of the bulb, so not a good idea to use as a "flash" unit ...  :)
HTH
Edited for smelling pistakes .. :(
« Last Edit: 27 March 2009, 13:26:23 by entwood »
Welung666
Re: Flashing.
« Reply #2 on: 27 March 2009, 13:46:07 »
HTH
 ;D ;D ;D
Ironingboard
  • Edinburgh
Re: Flashing.
« Reply #3 on: 27 March 2009, 14:09:58 »
Interesting, what is the story with new cars which have BI-Xenon headlights, I'm guessing the HID is always charged ready for use? Or am I completely wrong  ::)
Welung666
Re: Flashing.
« Reply #4 on: 27 March 2009, 14:12:20 »
Shutters ;) Lights are always on and shutter uncovers them :y
