Author Topic: Safe battery charging/jump starting  (Read 1619 times)
golden_delicious
  • Kingston upon Hull
« on: 28 March 2009, 08:47:31 »
Hi everyone,
This might sound silly but is it safe to charge the battery in the car while still connected ?also where should the jump leeds be connected if a jump start is needed (like when hubby leaves his lights on) ;D
Our hamfisted effort got the tractor going but put the radio into safe mode whoops.
There are only 10 types of people in the world, those who know binary and those who dont ;-)
Welung666
Re: Safe battery charging/jump starting
« Reply #1 on: 28 March 2009, 08:54:08 »
For trickle charging I always take off the negative lead and leave it charging. For a booster pack start use the battery terminals and for jump leads you should really use the + on the battery and a good solid ground point on the chassis/engine.
« Reply #2 on: 28 March 2009, 09:18:16 »
You can leave a battery connected while using a battery charger.
golden_delicious
« Reply #3 on: 28 March 2009, 09:20:31 »
Thanks for that we did jump start straight from the terminals but apart from the radio I think we got away with it. :y
Any suggestions for the best accesible earth point?
« Last Edit: 28 March 2009, 09:21:36 by golden_delicious »
« Reply #4 on: 28 March 2009, 09:51:54 »
not suprising the radio code is needed. You will also need to reset the one touch windows(hold switch in the up position for a couple of seconds)and reset the sunroof (hold the dial in open then closed then tilt position) hth
golden_delicious
« Reply #5 on: 28 March 2009, 09:59:44 »
Thanks CG I hadn't realised the one touch wasn't working ..fixed now  :)
Hubby's tractor hasn't got a sunroof so no problem there,and the radio is ok again .
Thanks for the help everyone :)
vauxmad
  • Oswestry, Shropshire
« Reply #6 on: 28 March 2009, 13:21:06 »
yeah the radio will always need the code after needing jump starting and as said the elec windows will need re setting by moving htem all the way down then all the way up.
