Author Topic: change rear shocks on an Estate  (Read 1592 times)
CBH
  • West Sussex
« on: 26 March 2009, 15:26:41 »
Hi
Is there a "how to" change the rear shocks on an estate.
I can see the bottom mount but how do I get to the top mount.
Also any tips on removing  the bottom bolt as I understand this can be a real B*t*h
Thanks
cbh
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: change rear shocks on an Estate
« Reply #1 on: 26 March 2009, 18:43:57 »
Lift the cover over the spare wheel well & the top nuts are there
I watched mine being changed & the lower ones were assisted with plus-gas and taps from a hammer
« Reply #2 on: 26 March 2009, 18:58:25 »
..... and taps from a hammer
you mean they beat ten colours out of them?  :-/  ;D   ;D
« Reply #3 on: 26 March 2009, 20:04:42 »
Ive removed the top bolts to change springs.
You need to pull the carpet back beyond the wheel well to access em.
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #4 on: 27 March 2009, 18:31:57 »
Easy enough jobbie this .....
The bottom attachment has a counterbore for the sleeve to fit snugly into. This can be a bit tight, but some reasonable thumping with a hammer will detach it.
Never failed to do it yet!
vauxmad
  • Oswestry, Shropshire
« Reply #5 on: 27 March 2009, 21:03:06 »
i tend to drench bottom bolts in wd40 several times over and then give it some welly. some cars are better than others
CBH
  • West Sussex
« Reply #6 on: 30 March 2009, 11:35:11 »
Change the shocks on Sunday morning the bottom bolts were no problem but I had to drill and split the Near side top nut.
 Put a pair of KYB gas shocks (£22 ea) on as they were cheep and I did not want to spend to much on the car as it has done over 200k and is 12 years old just needed to get an MOT.
Seth
« Reply #7 on: 30 March 2009, 12:40:27 »
As long as you're happy, job done then!
PxMetro
  • Stamford
  • Maryland Cookies are brilliant for dunking
    • 3.2 MV6 Estate
« Reply #8 on: 30 March 2009, 13:09:24 »
Yep that sounds familiar. I had exactly the same problem when I changed mine last year, and resorted to the same resolve. Difficult to stop the centre rod turning while undoing the nut.
Page created in 0.084 seconds with 16 queries.
