Author Topic: FIRST QUESTION:- LEAK FROM CAM COVER  (Read 2084 times)
over50now
  • Hertfordshire
« on: 29 March 2009, 20:22:51 »
Did cam covers about 200 miles ago. Now notice got very slight oil leak from rear of bank 1 or 2 (Where the half moon is).
Don't think I put enough of a blob of sealant there.
Correct torque applied.
Can I get away with resetting the gasket with more sealant, or do I have to replace the gasket.
Many Thanks.
Graham
IAM & ROSPA Gold Grade driver
Re: FIRST QUESTION:- LEAK FROM CAM COVER
« Reply #1 on: 29 March 2009, 20:28:52 »
just re seal it, unless the seal is damaged. Did you use genuine vx gaskits and o rings? Black goo used to be loctite 598 or what ever the superceded number is now.
over50now
  • Hertfordshire
« Reply #2 on: 29 March 2009, 20:37:03 »
Thanks Chris.
Got gaskets from mechanic mate. Had them in his garage. They weren't in vx livery - so no.
But will give it a go, 'cos I only put a smear of sealant over the half moon and none on the seat.
Cheers again. Graham
« Reply #3 on: 29 March 2009, 20:39:14 »
i would replace the gaskets with genuine, pattern ones don't last long!
« Reply #4 on: 29 March 2009, 21:48:01 »
never used non genuine personally, but they say youll be doing the job again in a couple of months time.
If your taking it apart again, i would consider fitting genuine for the sake of the ignition system and waisted time and effort.
Anyone know the correct seal stuff/black goo that replaces 598 or whatever?
ScottieMV6
  • Swinton, Manchester
« Reply #5 on: 30 March 2009, 09:16:50 »
If you get it from Vx its 90485251  :y
I'd rather be scared to death than bored to death!!
« Reply #6 on: 30 March 2009, 09:19:03 »
Its not 598!
I have tried pattern gaskets including Elring from auto vaux and FAI ones....both were shite lasting at max 6 months.
And as I have already carried out said experiment, hopefuly it wil save others from doing the same!  :y
« Reply #7 on: 30 March 2009, 09:33:21 »
Its not 598!
so what is it then!
« Reply #8 on: 30 March 2009, 09:37:10 »
Loctite 5910....598 is a flanger sealent for the likes of the diff rear plate
« Last Edit: 30 March 2009, 09:39:03 by Mark »
« Reply #9 on: 30 March 2009, 10:12:15 »
i am under the impression 598 ,as said, is no longer available and 5910 is the superceeded equivelent, it was the 5910 number i could not remember. if 598 is not to be used, maybe you could have informed me in the thread below!
http://www.omegaowners.com/forum/YaBB.pl?num=1223153437/0
over50now
  • Hertfordshire
« Reply #10 on: 30 March 2009, 12:02:09 »
Thanks guys.
Loctite 5910 then.
 :y :y :y
mkaminski100
  • Basingstoke
« Reply #11 on: 30 March 2009, 13:03:43 »
I got fed up and replaced covers with Vectra V6 ones. When doing my Vectra V6 I have reused old gaskets and after 6 months, no leaks! Covers have to swapped (left to right) so oil has to poured in far left corner.
vauxmad
  • Oswestry, Shropshire
« Reply #12 on: 30 March 2009, 15:38:41 »
yeah get gen ones and make sure you get enought things out of the way, don't be tempted to just stuff the covers through a tight gap and hope for ht best. they will be dislodged and endup leaking from not being seated properly
