Author Topic: coolant level low warning but level ok  (Read 1319 times)
omega trev
  • hull east yorkshire
« on: 30 March 2009, 20:11:08 »
hi all
as above im getting coolant level low every now and then its not consistant but on inspection the level is fine. just wondered if anyone had any ideas?
Re: coolant level low warning but level ok
« Reply #1 on: 30 March 2009, 20:13:09 »
hi all
Float in the header is sticking. You could try giving the bottle a good cleaning or replace it with a new one for around £30  :y
Danny S
  • Dordrecht,NL
  • Omega 2.2-16v Elegance
« Reply #2 on: 30 March 2009, 20:15:23 »
Sensor in coolant unit maybe broke down or loose wire or connector.
Clean up the connector of the unit maybe it helps.
gr
Danny
Omega 2.2-16v Elegance Auto
omega trev
« Reply #3 on: 30 March 2009, 20:16:11 »
cheers mate ill give it a go
vauxmad
  • Oswestry, Shropshire
« Reply #4 on: 30 March 2009, 22:14:26 »
if you have no luck cleaning it have a known working one for sale from the car i am breaking, pm me if interested
mkaminski100
  • Basingstoke
« Reply #5 on: 31 March 2009, 08:39:41 »
If that’s not a seized float, you can still fix it. If the message is permanently on your screen, it a magnet that does not stick to a float and you have to cut small pin inside the tank to get the plastic washer, float and a magnet. Stick it together with a high temp glue/silicon, put it back and secure it using a soldering tool. If the message is there only when the engine is warm/cold, it’s a sensor underneath the tank. Cut the lip around it so that you can take it without much force. Then you have to cut the sensor with knife or small saw where the circuit board joins both pins. It’s a hard job but I did it in 20 minutes. Solder it again, cover in black silicon, glue it back to the tank (with silicon) and fixes. BTW – there will be no leakage if you’ll take the sensor out!
