Author Topic: Can't drop diff  (Read 3313 times)
chrisdb
  • Chesterfield
Can't drop diff
« on: 31 March 2009, 15:45:34 »
Hi all
Just replacing my rear springs. I've been following the how to and everything is fine - except that having undone all the bolts the diff will not drop. I've bounched the wheels (gently) but no joy.
And yes, the four bolts into the subframe are out, as well as the roll bar to semi trailing arm bolts.
Any ideas?
TC Card, will buy parts for members near by. V6 Camshaft locking kit can rent out to members at club rates.
P_Russell
  • Rushden, Northants
Re: Can't drop diff
« Reply #1 on: 31 March 2009, 15:58:28 »
This might sound daft - but I did it......
Where are your axle stands located?  anywhere on the rear subframe by any chance??
If it's stuck, force it.  If it breaks, it needed replacing anyway........
chrisdb
  • Chesterfield
Re: Can't drop diff
« Reply #2 on: 31 March 2009, 16:07:50 »
Ah... oh dear.  :-[ Do you think it's safe to jack the car up under the diff so I can move them?
Cameron
  • Morayshire
Re: Can't drop diff
« Reply #3 on: 31 March 2009, 17:08:39 »
Ah... oh dear.  :-[
 ::) ;D
I take it that it's much easier to change the springs if you drop the rear subframe then?
« Last Edit: 31 March 2009, 17:20:33 by Kamykasie »
Re: Can't drop diff
« Reply #4 on: 31 March 2009, 19:13:10 »
Ah... oh dear.  :-[
 ::) ;D
Christ yes....45 mins all in!
Re: Can't drop diff
« Reply #5 on: 31 March 2009, 19:13:53 »
Lol, slot the jack in from behind so you jack the trailing arm and pop the stands under the rear subframe bush plate where you normaly jack
vauxmad
  • Oswestry, Shropshire
Re: Can't drop diff
« Reply #6 on: 31 March 2009, 20:10:00 »
oh dear, still easy done lol
Re: Can't drop diff
« Reply #7 on: 31 March 2009, 20:43:10 »
Lol, I will just quote the following from the mainenance guide
do not place these under the trailing arms as these need to be able to move for this job.
chrisdb
  • Chesterfield
Re: Can't drop diff
« Reply #8 on: 31 March 2009, 20:56:49 »
Cheers! All done  ;D. I did see that bit, but silly me thought it was just the trailing arm that the wheels hang off!! Wasn't till I looked closer I spotted the schoolboy error!
Cameron
  • Morayshire
Re: Can't drop diff
« Reply #9 on: 31 March 2009, 21:14:00 »
Ah... oh dear.  :-[
 ::) ;D
Sweet!
I think I'll put my original (slightly broken) springs back in after the mot...these stupid lowered springs are pump.
Mike Collins
  • North of Bristol
Re: Can't drop diff
« Reply #10 on: 31 March 2009, 21:54:37 »
Watch out when you tighten the mounts, it's very easy to pinch the fuel pump wiring, done that, blows a fuse and generates more work.
Cameron
  • Morayshire
Re: Can't drop diff
« Reply #11 on: 31 March 2009, 22:13:11 »
I know its chrisdb's thread but thanks for that!  :y
chrisdb
  • Chesterfield
Re: Can't drop diff
« Reply #12 on: 03 April 2009, 08:56:09 »
New springs and shocks are wicked ;D ;D :y
P_Russell
Re: Can't drop diff
« Reply #13 on: 03 April 2009, 09:04:49 »
Hooray - my first bit of successful advice! :D
Always good to learn from mistakes, but even better when those mistakes are someone elses!!
chrisdb
  • Chesterfield
Re: Can't drop diff
« Reply #14 on: 03 April 2009, 09:07:05 »
Yes, thanks  ;) I'm sure you'll have many more :y
