Author Topic: Omega running hot  (Read 2009 times)
Miggy24
  • Exeter,Devon
Omega running hot
« on: 04 April 2009, 18:17:18 »
Hi all my omega has started running hot this afternoon, it was running near 100 on the temp then the fan cut in at 100 then the temp went down but soon as the fan stopped the temp went back up again so i dont know if the water pump has gone or what.Any well would be good.Oh yeh no water has been lost and when i drove back after letting it cool i drove slow and the temp didnt really go really high
« Last Edit: 04 April 2009, 18:19:18 by devonboy2008 »
Re: Omega running hot
« Reply #1 on: 04 April 2009, 19:19:03 »
Sounds like a faultty sensor.  Or could be a loose pluc/connection.
At first I was going to say an airlock but as I carrid on reading you mentioned the fan kicking in late.  Maybe still worth chacking though.
« Reply #2 on: 04 April 2009, 20:07:32 »
Thermostat..
Miggy24
  • Exeter,Devon
« Reply #3 on: 04 April 2009, 20:20:33 »
wont be a sensor as my car has the ol carlton engine in
Danny S
  • Dordrecht,NL
  • Omega 2.2-16v Elegance
« Reply #4 on: 04 April 2009, 20:36:45 »
I think its the waterpump though.
The blades(?) of the pump is loose from the spindle.
greetings
Danny
Omega 2.2-16v Elegance Auto
Miggy24
  • Exeter,Devon
« Reply #5 on: 04 April 2009, 20:53:58 »
It might be the pump but its easyer to check the thermostat first then the pump but surly if its the pump the temp would be runningin the red and not cooling down at all
Radar
  • Berkshire
    • Elite 2.5 Auto
« Reply #6 on: 04 April 2009, 21:05:30 »
Does your radiator have 2 cooling fans? If so sometimes the fuse goes on them.
Danny S
  • Dordrecht,NL
« Reply #7 on: 04 April 2009, 21:14:40 »
If the blades are loose from the spindle it would be cooling by low rpm if the rpm is going up the spindle goes faster then the blades and could not run the water fast enough to cool as it should be.
But checking the thermostat is probably the first to check :y
gr
Danny
Miggy24
  • Exeter,Devon
« Reply #8 on: 05 April 2009, 13:27:18 »
Got the car sorted now it was the Thermostat at fault :y
« Reply #9 on: 05 April 2009, 17:25:15 »
good to hear its sorted :y
