Author Topic: Drivers door has developed the check-strap issue  (Read 1761 times)
BigAl
  • Bromley, Kent
    • '07 Forester
« on: 08 April 2009, 21:45:29 »
Guys back in september,  i applied the recommended fix even though neither door had been noisy, as detailed here - http://www.omegaowners.com/forum/YaBB.pl?num=1152902108
over the last few days my drivers door has started the dreaded clicking when opening
Any pointers ?
stevief
  • Aberdeen
Re: Drivers door has developed the check-strap issue
« Reply #1 on: 08 April 2009, 23:31:27 »
Probably just the plastic bushes, same noise on mine was cured and has been fine since.
I take it the clicking is at that end and not in the door.
Steve
« Reply #2 on: 09 April 2009, 07:40:58 »
Were enough weetabix used to tighten the bolts?
They can start clicking again if they work a litte loose.
I would try a quick tighten first.
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #3 on: 09 April 2009, 07:54:44 »
I have changed the bush about a year ago and have again the problem/noises. Tried to put a new bush without any change. Seems that the bolt has worn. Or the hole in the strap. Has anyone made a replacement bushing out of brass/some other materila? Does it have to be the plastic one which wears in a few months? Any other ideas to make it better than new?
