Author Topic: supposed to be at work  (Read 2931 times)
hoj
  • BURY
« on: 09 April 2009, 08:49:59 »
sat here waiting for a lift as AGAIN the car wont start (wont fire)
my last post on this matter was over 2 weeks ago since then it has started everyday at least 10 times a day and covered around 750 miles runs great when its running have been tols its the crank sensor.
So for one last time before i spend £70/£80 on one is it normal for the crank sensor to behave like this starts ok then wont start then starts for 2 whole weeks then suddenly this morning wont start again
I am just amazed that a sensor could act this way
3.2 Elite in Oyster
Welung666
Re: supposed to be at work
« Reply #1 on: 09 April 2009, 08:51:12 »
Do a paperclip test while your waiting and post the codes.
« Reply #2 on: 09 April 2009, 09:07:38 »
So for one last time before i spend £70/£80 on one is it  ......
Omega Part Number           Retail Price            Normal Trade       Trade Club
Crankshaft sensors
2.0 8v 90493864                £55.50                    £49.96                    £43.04
2.0 16v to 14194716 90458251 £55.50             £49.96                    £43.04
2.0 16v from 14194717/31000001 9174621£33.60    £30.29           £25.96
2.5 (early models) 90492006       £76.50                  £68.85          £59.23
2.5 (later models) 90492061      £55.50             £49.96               £43.04
2.6/3.0/3.2 90540743              £49.70             £44.78                  £38.38
2.0DTi/2.2DTi 90540188           £35.65           £32.09                      £26.73
U25TD/X25TD  90487810             £80.00           £72.00                   £61.97
I'm guessing yours is the highighted one. If you want a 'real' one I could order you one on Trade Club if you wanted ....  ;)
« Reply #3 on: 09 April 2009, 09:09:15 »
Well, you had the warning signs and didn't act......lets hope you dont ever have a mild heart attack  :y :y (joke!)
Read the fault codes and then get it sorted, the senors can be got for sub 50 quid and fitting is easy.
They can be intermittent. The common failure is the wire breaking down which can cuase intermitent working (which should be no surprise!), sometimes they do simply die.
Other possibles are failing sensors which get weak signals, these can cause poorer starting which takes more cranking as a first sign of it going.
hoj
  • BURY
« Reply #4 on: 09 April 2009, 09:25:32 »
There are NO codes listed/none in memory
3.2 Elite in Oyster
« Reply #5 on: 09 April 2009, 09:26:51 »
There will be at least a 31....with the engine not running
hoj
  • BURY
« Reply #6 on: 09 April 2009, 09:27:53 »
May end up in cars for sale shortly i cant keep losing money at work having days off                 .(how much anyone)
« Last Edit: 09 April 2009, 09:33:48 by hoj »
3.2 Elite in Oyster
hoj
  • BURY
« Reply #7 on: 09 April 2009, 09:33:13 »
yeah 31 and 12 thats it no other codes
3.2 Elite in Oyster
hoj
  • BURY
« Reply #8 on: 09 April 2009, 09:36:14 »
Thanks Andy i need to know its definately the crank sensor first i just cant get my head round it working one minute then not the next  thats all
3.2 Elite in Oyster
Martin_1962
« Reply #9 on: 09 April 2009, 09:37:10 »
Crank sensor and the cable gets cooked.
Most common bad starting issue
« Reply #10 on: 09 April 2009, 09:37:53 »
 i need to know its definately the crank sensor first  ....
For less than £50 I'd change it.  ;)
Martin_1962
« Reply #11 on: 09 April 2009, 09:38:19 »
It can operate with a failing sensor - ie not every rev found, but bad starting is the clue - I bought mine from an Ebay seller - just as a post strike started >:(
« Reply #12 on: 09 April 2009, 09:42:24 »
Dont be soft, just fit a genuine vx sensor. I say genuine as £80 is far too much so presume you paid over the odds for a copy, or does that include fitting or something, its a 5 minute job . When and where did you get it and who fitted it?
hoj
  • BURY
« Reply #13 on: 09 April 2009, 09:46:06 »
i aint got one yet but around £70/£80 was quoted to me to buy and fit.
Is there a guide on here anywhere
3.2 Elite in Oyster
Robmetaxa
  • Southampton
« Reply #14 on: 09 April 2009, 09:51:08 »
 :)Yep thats the very same symptoms I had, failed to start, then would after about 30 mins, then would be ok for a week or so then failed to start again! Mine was the Crank Sensor as correctly told on here, cost me £142 at a garage cos it was during the winter I really couldn't be a@@ed to get under there myself, done an oil change last week and saw where it is and looks real easy to change tho!!
Rob
