Author Topic: fitting 3.0 cams  (Read 1914 times)
Richard148
  • solihull. w,mids
fitting 3.0 cams
« on: 09 April 2009, 17:08:55 »
when installing these is there anything else i will need to do the job? :-/ (got all tooling)
« Last Edit: 09 April 2009, 17:13:23 by Richard148 »
Re: fitting 3.0 cams
« Reply #1 on: 09 April 2009, 17:24:33 »
Cam cover gaskets
Green Sealent for front cam bearing cap
Black sealent for cam covers
Camshaft oil seals (may be possible to re-use but at least have a couple handy in case they are damaged during removal / installation.
May as well change cam belt and tensioners if it's getting close to "that time".
That should just about do it IIRC.
Richard148
  • solihull. w,mids
« Reply #2 on: 09 April 2009, 17:34:57 »
Cam cover gaskets
the reason I'm changing the cams is i need to do the cover gaskets so i thought while I'm there i may as well :y
whats the difference between the to sealants and whats the damage to buy it?
how much for cam oil seals?
belt and tensioners arnt that old so im ok there :y
« Last Edit: 09 April 2009, 17:36:08 by Richard148 »
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #3 on: 09 April 2009, 17:50:36 »
just been to vx dealer in hull mate.
doing mine tomorrow  :y
pack of 2 cam cover seals part number 90511451 £26.33 + vat
tube of sealing compound ( green ) * 90542114   £5.45 + vat
asked and they told me the sealant is just green nowdays but it seems a bit runny  to me  :-/
opinions anyone ?
Richard148
  • solihull. w,mids
« Reply #4 on: 09 April 2009, 17:55:12 »
opinions anyone ?
cheers mate :y
MutantCav
  • Gainsborough
« Reply #5 on: 09 April 2009, 19:11:53 »
They are talking out their backsides...black sealant for cam covers IS needed or you will be doing the job again very soon
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #6 on: 09 April 2009, 19:29:25 »
from the sound of it my vx dealer hasn't got a f*cking clue mate.
scrap the green  :y
Richard148
  • solihull. w,mids
« Reply #7 on: 09 April 2009, 20:15:37 »
bloody vx dealer/cowboys are thay all there on a YTS or somin >:(
thanks all for the info :y
« Reply #8 on: 09 April 2009, 22:25:53 »
scrap the green  :y
Black sealant part nş 90485251 £3.28 on TC - big tube as well :y
« Reply #9 on: 09 April 2009, 22:32:03 »
The two sealants are very different too. One is a thin sealant for sealing metal flanges. The other is a RTV style.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #10 on: 10 April 2009, 02:50:46 »
If your doing your Cam Covers aswell as your Gaskets & Sealant you will need "O" rings too 16 of them :y
« Reply #11 on: 10 April 2009, 07:30:51 »
Yep, you need the O rings.
I suspect a VERY thin wipe of the black sealent would suffice on the front cam bearings to save the cost of both sealents.
Dont forget the cam cover bolt O rings (16 in total)
The 3.0 lower inlte manifold bridge piece is also less restrictive then the 2.5 one.
Obviously cam cloking kit is needed.
Re-use the cam bearings seals, never had an issue in ALL the ones I have done and the after market seals are crap and leak
