Author Topic: Breathers  (Read 1343 times)
damon80
  • Wigan
Breathers
« on: 14 April 2009, 11:32:34 »
Hi Folks,
I'm going to have a crack at cleaning out the breathers today.
I've had a look at the maintenance guide, which is very useful.  But, I can't see how you'd get access to the breather box - is it something I'd need to take the scuttle off to get to?
Also, I don't have any carb cleaner - would WD40 do the job??
Cheers  :y
ians
  • Reading
Re: Breathers
« Reply #1 on: 14 April 2009, 11:54:09 »
You need carb cleaner -  WD40 is a water dispersant, not a cleaner.
It is possible just removing the plenum, although can be a bit fiddly getting the hoses and clips on and off.
damon80
  • Wigan
Re: Breathers
« Reply #2 on: 14 April 2009, 12:00:31 »
Cheers Ian - will have a dabble later on
jjleonard
  • stevenage
Re: Breathers
« Reply #3 on: 14 April 2009, 12:51:37 »
If you're feeling brave (and doing the cam cover gaskets at the same time!) removing the driver side cam cover makes it a lot easier to get to.
Removing the large breather pipe that splits into two at the plenum breather box can be a pig if the cam cover and assorted other gubbins is in the way. :y
« Last Edit: 14 April 2009, 12:51:51 by jjleonard »
