Author Topic: Part num, 3.0v6 crank sensor?  (Read 928 times)
omegod
  • liverpool
    • 2017 Seat Ateca
« on: 17 April 2009, 11:42:51 »
Hi chaps,
Fault code 19 and dodgy starting so new crank sensor required!
£90 quid from stealers FFS so may go pattern, stealers werent sure if this is the right one and web search shows a bit of confusion over types/shapes.
Any feedback on pattern ones welcome but definitive part number would be helpful. mini facelift made in 99 but registered in 2000.
Re: Part num, 3.0v6 crank sensor?
« Reply #1 on: 17 April 2009, 11:45:23 »
think thats the oval connector one.
I know a lot of people have bought pattern ones and they HAVENT solved the issue.
You may be lucky, or you maybe adding the cost of a cheap one to a good one.
Is there someone local with tradecard access could help you out?
or pm andyc (i think) he can likely supply you a new genuine one cheaper than that.
« Reply #3 on: 17 April 2009, 18:59:42 »
Likely to be oval plug one bud - 90492061 - £43.04 + VAT on Trade Club - believe AndyC will give you similar prices.  He certainly ships parts quickly :y
