Author Topic: turbo  (Read 1729 times)
richy08
  • sheffield
turbo
« on: 18 April 2009, 20:07:59 »
hi guys my turbo is making a glassie noise when winding up do u think it on the way out thanks  :y
platty
  • Cambridge
    • BMW 530d Sport
Re: turbo
« Reply #1 on: 20 April 2009, 14:52:10 »
What exactly is a glassie noise? I can hear mine whistling a bit when the window is down, but not sure what other noises it makes?
mathewst
  • Split, Croatia
    • v40
Re: turbo
« Reply #2 on: 20 April 2009, 15:00:11 »
How much miles did the car make?
Maybe the turbo is in need of cleaning, but I'm afraid it has to be done by a skilled mechanic
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: turbo
« Reply #3 on: 20 April 2009, 15:28:45 »
A bit of whistling is perfectly normal on the 2.5TDs.
In fact, I've yet to hear one that doesn't whistle.
If yours is making a 'whooshing' sound, then it's likely that the intake   hose is not seating correctly to the turbo, or even come adrift. Should this be the case, it needs to be looked at ASAP, as you'll effectively sandblast the pistons with non-filtered air.
« Last Edit: 20 April 2009, 15:30:15 by Reliance505 »
richy08
  • sheffield
Re: turbo
« Reply #4 on: 20 April 2009, 18:05:25 »
its like a steel on steel noise when spining thanks guys
Seth
Re: turbo
« Reply #5 on: 20 April 2009, 18:20:56 »
Right, with the engine COLD, remove the intake pipe, and feel for wear in the turbine bearing.
Do this by trying to move the centre nut in an up/down and side-to-side movement. You may also find some metallic deposits inside, caused by the vanes contacting the housing.
richy08
  • sheffield
Re: turbo
« Reply #6 on: 20 April 2009, 18:23:51 »
is it fixable or a new one needed
Page created in 0.023 seconds with 16 queries.
