Author Topic: Accelerator cable adjustment  (Read 1408 times)
markfree
« on: 08 May 2009, 12:25:26 »
There is approx 1/2 - 1" play in the accelerator pedal - how & where is the best place to adjust i.e. at the pedal end of the cable or at the plenum end?
Cheers for any advice.
Re: Accelerator cable adjustment
« Reply #1 on: 08 May 2009, 12:30:52 »
Up at the plenum end... IIRCC there's a slide which goes over the grove in the cable outer casing
« Reply #2 on: 08 May 2009, 12:32:34 »
^^^  Wot he said, can make a difference to kickdown, and acceleration if too slack.
Welung666
« Reply #3 on: 08 May 2009, 12:42:27 »
As above, don't make it too tight though, you still want about a 1/4" of play. 1" is excessive.
markfree
« Reply #4 on: 08 May 2009, 15:12:13 »
Some idiot ( ::)) had put the clip on the wrong side so there was 2 inches of play ( :o)- no wonder kickdown wouldn't work and even old grannies on there eleccy chariots were overtaking me.
Thanks for the advice guys :y
« Reply #5 on: 08 May 2009, 15:15:10 »
Some idiot ( ::)) had put the clip on the wrong side .....
I hope he/she gets a bollocking when you catch up with him/her!  ;)  ;)  ;) :y
ians
  • Reading
« Reply #6 on: 08 May 2009, 15:27:38 »
its a wonder it went at all..
