Author Topic: cruise controll help  (Read 1328 times)
bellers
« on: 18 May 2009, 20:16:08 »
my cc only works for about 5-10mins of driving then wont go back on again.
doesnt cut out when its on though just wont go back on after turning of or if i dont use it and go to use it after 5 r 10mins it wont go on
any suggestions?
Agemo
  • Cleethorpes
  • Insignia
Re: cruise controll help
« Reply #1 on: 18 May 2009, 20:20:34 »
I would suspect the switch first.  If you post your location, there may be someone near, who could lend you one, so you can try before you buy.  Remember yours is the two wire job, not three like the Petrol models.   ::)
« Last Edit: 18 May 2009, 20:20:54 by Agemo »
« Reply #2 on: 18 May 2009, 20:24:21 »
4 ;)
« Reply #3 on: 18 May 2009, 20:25:04 »
any suggestions?
try paperclip test on it, see if engine ecu is detecting a fault
in limp mode, cruise may be disabled....
« Last Edit: 18 May 2009, 20:25:41 by TheBoy »
bellers
« Reply #4 on: 18 May 2009, 20:52:43 »
doesnt come on when its of. would the eml not be on if its in limp mode?
ill try paper clip test to night maybe or tomorrow night
« Reply #5 on: 18 May 2009, 21:02:18 »
No, of course the EML doesn't come on - its a BMW system, and having the EML come on would deem them as reliable as they truely are ;D
Agemo
  • Cleethorpes
  • Insignia
« Reply #6 on: 18 May 2009, 21:48:09 »
"Three"
Doh!
I meant four.   :o
bellers
« Reply #7 on: 18 May 2009, 22:14:54 »
done the paper clip test
37      Incorrect Brake Switch Signal
