Author Topic: Door check strap washers  (Read 2263 times)
bigdods
  • Brackley
« on: 23 May 2009, 11:55:17 »
Both front doors have been click clacking for a while now. Both washers were replaced about a year ago but hey ho, not exactly expensive. While I was at my local Vaux dealer this morning I picked up 4 new washers, but when I went to fit them I found that the bolt was loose in the check strap. I just tightened it up and no more click clack.
The question I have is, should the bolts be tight or do they need some slack. Having tightened them up am I just hiding the problem, should I still change the washers ?
« Last Edit: 23 May 2009, 11:56:11 by bigdods »
Re: Door check strap washers
« Reply #1 on: 23 May 2009, 11:56:54 »
Tight as you can.
Mine worked loose after initial change.
not enough weetabix problem  ;D
« Reply #2 on: 23 May 2009, 13:33:05 »
Tight as you can.
Disagree - I'd go for 'just nipped up' and check them again in a few weeks to ensure they haven't worked loose
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #3 on: 23 May 2009, 20:18:28 »
Tight as you can.
That's right - the nuts are nyloc type anyway, so shouldn't work loose.
arlee219
  • Birmingham
« Reply #4 on: 23 May 2009, 21:32:50 »
Had the same problem, but after applying some WD40 and tightening  them up all prob's gone.
2.2 CD Auto LPG Conv Xreg
« Reply #5 on: 23 May 2009, 22:09:53 »
I'd change the bushes. about 20p each. They are designed to be dry lubricated so they don't attract too much shite.
Also, WD40 is NOT a lubricant.
« Reply #6 on: 23 May 2009, 22:12:42 »
It is actually  ;) .... it's just that there are other more suitable lubricants available!
http://www.wd40.co.uk/index.cfm?articleid=1519
« Reply #7 on: 23 May 2009, 22:13:49 »
Branston claim they make the best bean, but we both know they lie ;)
« Reply #8 on: 23 May 2009, 22:18:15 »
..... but we both know they lie ;)
 :y The best come from some place in Wigan!  :y
webby23
  • Nottingham
  • MV6
« Reply #9 on: 24 May 2009, 07:58:16 »
Totally agree......Tesco Value beans are much much better
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #10 on: 24 May 2009, 13:52:38 »
Hope you all had your best "bib & tucker" on for Betty's visit last week.
TuBy's new whipping boy.
« Reply #11 on: 24 May 2009, 14:08:49 »
never understood the wd bashing on here, i have it down as a good all rounder,
ie. ok at most things but does not excell at any, if its all you have then its better then nowt.
« Reply #12 on: 24 May 2009, 17:25:53 »
Its really good at bringing black plastic back to black.  Its a so-so release oil.  Not much cop at anything else though
« Reply #13 on: 24 May 2009, 21:17:07 »
Oh yes!  ;D ;D Clean boiler suit & new Hi-Viz straight out of the packet! I was just out of camera shot!  ;D ;D
Prince Philip was running here there & everywhere, not bad for a bloke of his age!  :y :y
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #14 on: 24 May 2009, 21:22:32 »
Looking for a bar? ;D ;D
