Author Topic: HELP Car only running on 3 cylinders  (Read 5847 times)
Martin_1962
Re: HELP Car only running on 3 cylinders
« Reply #15 on: 05 June 2009, 22:59:23 »
If theres no compression on that bank then I would have thought a load of bent valves.Timing slipped?,broken camshaft? :-/
I hope not - they cost enough
Martin_1962
« Reply #16 on: 05 June 2009, 23:09:02 »
Tomorrow I am going to strip (if dry)
Then I will know what is what
But very odd what happened
I was expecting 135 to leak but not 246 to conk out
« Reply #17 on: 05 June 2009, 23:10:37 »
tomorrow is another day , go get some rest :y
« Reply #18 on: 05 June 2009, 23:41:14 »
Only thing I can think of is that the timing has slipped (cam has rotated on the sprocket?). Can't remember how the cams are keyed to the sprockets on this engine. There's a dowel between them IIRC? Possible it was left out during the cam swap?
Could the lifters have pumped up so hard that the valves are not closing? Excessive oil pressure perhaps? If so why only one bank?
Slipped cam timing seems the most likely explanation I'm afraid.   :'(
Martin_1962
« Reply #19 on: 06 June 2009, 09:24:58 »
Locating pin on cam 3 has snapped >:( :( :'(
Martin_1962
« Reply #20 on: 06 June 2009, 12:23:03 »
The valves are still sealing
They don't look bent
Will pop out one and check
Looks like I was VERY lucky
Small marks on the piston heads
« Reply #21 on: 06 June 2009, 12:33:23 »
Wouldn't explain the lack of compression...
« Reply #22 on: 06 June 2009, 12:37:02 »
If the pin hadn't located between the cam & its pulley then the cam wouldn't have been turning, hence no compression! Obvioulsy depends where the cam had parked itself as to whether there would be bent valves.
KillerWatt
« Reply #23 on: 06 June 2009, 12:43:48 »
The marks on the crown of the pistons, along with your confirmation of a "noise" means (unfortunately) there was very much definately some contact.
Although the valves may look as though they are still seating properly, the only definitive test you can do (other than removing the actual valves) is to invert the head (balance it so it is flat) and pour a small amount of petrol in to each chamber with all the valves closed.
If the fluid level hasn't dropped after (say) 30 minutes, then you have more than likely got away with it.
Good luck  :y
« Reply #24 on: 06 June 2009, 12:45:14 »
Good luck  :y
Sounds like Martin could do with a bit more help than luck ..... maybe a miracle! ::)  :y  :y  :y  :y
Martin_1962
« Reply #25 on: 06 June 2009, 12:46:33 »
I removed one valve - no runout
I left petrol in them for about 1/4 hour and no drop
I think they just slipped timing
The cam was turning
May be it was opening 180 out so during power
Martin_1962
« Reply #26 on: 06 June 2009, 12:49:10 »
Good luck  :y
I think there was about 4 or 5 hits per valve
Martin_1962
« Reply #27 on: 06 June 2009, 12:50:15 »
Being 180 out would, I noticed when dismanteling that 3 was ahead of 4
« Reply #28 on: 06 June 2009, 14:40:20 »
Good luck  :y
As a tip, paraffin tends to work better, as petrol evapourates a bit quicker :y
Martin_1962
« Reply #29 on: 06 June 2009, 15:10:32 »
Well 15 minutes and it was OK
Just going to seal the cam cover now
May not do much more as I am feeling crap
Pages: 1 [2] 3 4  All   Go Up
