Author Topic: HELP Car only running on 3 cylinders  (Read 5849 times)
Martin_1962
Re: HELP Car only running on 3 cylinders
« Reply #45 on: 07 June 2009, 09:54:34 »
Pulleys torqued but not angle tightened (old bolts), new positions marked, cam belt remarked and waiting to dry.
Baseplate torqued
Just going to tape some more charity bags together for rain protection
« Reply #46 on: 07 June 2009, 10:24:07 »
Locating pin on cam 3 has snapped >:( :( :'(
Why......they dont snap for no reason so whats the cause?
Were the cam bearings all fitted correctly?
No oil ways blocked are T vents missing?
Martin_1962
« Reply #47 on: 07 June 2009, 10:34:41 »
Not snapped - fell out
Refitted OK
Cam belt refitted
Cam belt cover done
« Reply #48 on: 07 June 2009, 10:36:37 »
Baseplate torqued
I wouldn't leave them at just 50nm. That's not enough. If concerned about re-use perhaps omit the final stage of angle tightening but the 50nm will just be to ensure they are making contact.
Martin_1962
« Reply #49 on: 07 June 2009, 10:38:58 »
DOne a bit more
Martin_1962
« Reply #50 on: 07 June 2009, 16:08:52 »
I drained about 2 litres of rain water out and a litre of oil after it.
On a test drive ran oin 6 but kept conking, EML light, emmisions light and TC light. Had to leep resetting the engine to pull away.
First stop found a vac hose had come off while refitting, then when I got home, wet DBW connector and slightly loose plenum.
Anyway some switch cleaner and a quick nip wnet for a test drive.
Ran fine, but a nob in a common rail TD Mondea pulled out on a RB then started to hammer it (new and very smokey). I had to back off as traffic coming the other way meant I couldn't overtake!
« Reply #51 on: 07 June 2009, 16:16:58 »
good news.. :y
you will have time to race later ;D so dont hurry :y
« Reply #52 on: 07 June 2009, 16:20:21 »
You're a lucky man Martin!
Martin_1962
« Reply #53 on: 07 June 2009, 18:31:02 »
I had to have some luck for a change
    • 530D M Sport, 330i Coupe
« Reply #54 on: 07 June 2009, 18:44:24 »
Remind me to bring the Opelscanner the next time I see you and we can reset all the stored codes.
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #55 on: 07 June 2009, 18:52:10 »
Think of the fuel that you'll save with only 50% of the engine firing ;D ;D
Martin_1962
« Reply #56 on: 07 June 2009, 19:08:06 »
It was no better than on 6
« Reply #57 on: 07 June 2009, 20:18:30 »
You should still angle tighten the cam bolts as per new ones.
Martin_1962
« Reply #58 on: 07 June 2009, 21:20:15 »
I just did the 60
When I haev changed the 135 gasket (again) I wil fit new cam bolts. Especially as I will be towing in 5 or 6 weeks
Pages: 1 2 3 [4]  All   Go Up
