Author Topic: Key fob battery replacement  (Read 1569 times)
howardmoon
  • Feltham
« on: 07 June 2009, 10:13:08 »
Hi, my keys are 11 years old and as far as I know still have the original batteries. lately I've noticed it doesn't always work first time, and I have to tap the key on something first. How do I replace the batteries, do I have to get Vauxhall to do it?
Cheers, Paul
Re: Key fob battery replacement
« Reply #1 on: 07 June 2009, 20:42:29 »
small indent in the back of the key,
either use this, or pull to separate fob from 'horseshoe key'  (take care not to lose immobiliser transponder, small black plastic bit)
then gently separate both sides of the fob, carefully remove and replace cr2032 battery, and reassemble.
You have about a minute to do this before the fob 'loses' programming
if it does, just key in ignition to position 1, then press either button, locks activate, and fob resync'ed.
enjoy!
KillerWatt
« Reply #2 on: 07 June 2009, 21:19:53 »
Check the battery post legs (the one in the corner), they have a habit of "fracturing" away from the PCB.
A slight pain to resolder, but can be done.
howardmoon
  • Feltham
« Reply #3 on: 08 June 2009, 16:42:55 »
Cheers guys, I'll do a google search for the battery type as replace the one in the spare key too. :y
markey mark
  • SLady bitshorpe north lincs
« Reply #4 on: 08 June 2009, 16:58:46 »
its a 2032 battery bud  :y
« Reply #5 on: 08 June 2009, 18:41:52 »
You should get one from any good Computer Shop - they are used on mobos to power CMOS!!
« Reply #6 on: 08 June 2009, 18:50:58 »
Sod that, any battery shop, supermarket, wilko's etc, one of the most popular out there!
« Reply #7 on: 08 June 2009, 18:54:43 »
Sod wot?? I used to sell em in my shop for £0.50 each!!  Rover dealers used to sell em (2 required in 827 key) for £6.50 each!!
« Reply #8 on: 08 June 2009, 19:13:18 »
No offence....these days good computer shop = online = delivery
pick em up in any number of shops in most towns now, from £1-3  :y
Martin_1962
« Reply #9 on: 08 June 2009, 22:04:03 »
I bought a pack of 50 for about £15
howardmoon
  • Feltham
« Reply #10 on: 09 June 2009, 12:06:03 »
Cheers guys, it turns out my computer on my pushbike uses the same battery and i've got a spare already. Changed and working just fine
Thanks, Paul :)
« Reply #11 on: 09 June 2009, 17:10:10 »
None taken ;)
